Coolant system question.
Old Jun 13, 2010 | 04:44 PM
Tunerguy1989's Avatar
Default Coolant system question.
This may be stupid to ask but how do I bleed the air out of my coolant system. Theres a little breather screw on the thermostat housing do I use that or is it simpler than that. Some one told me to just to let the car idle with the radiator cap off and top it off. Does that work to get rid of the air? I have a larger capacity radiator so I just want the system to be in top shape for the summer.
Thanks in advance
Old Jun 13, 2010 | 05:18 PM
Kronn 98SH's Avatar
Default Re: Coolant system question.
Helm's manual, Chapter 10, Page 5.
Old Jun 13, 2010 | 05:22 PM
saikou's Avatar
I've personally never used the bleeder screw method and have had no issues. Normally whenever I am dealing with coolant, I have the front end of the car jacked up because I'm draining coolant. I just leave the car running on stands in the front so the radiator fill neck is the highest point.
Old Jun 13, 2010 | 06:00 PM
khronicboy420's Avatar
why are you asking. Did you recently have a coolant flush. if so then its probably just a air pocket which is semi common, also has your car overheated?
Old Jun 13, 2010 | 06:03 PM
Kronn 98SH's Avatar
Originally Posted by khronicboy420
Why are you asking?
Old Jun 14, 2010 | 03:59 AM
minilogoguy18's Avatar
There's a screw on top of the thermostat, you'll know it when you see it, just loosen it and fill the radiator until a steady stream comes out with no bubbles then shut it and torque to 7 ft-lbs.
Old Jun 14, 2010 | 10:40 AM
ok great thx. i ll try that this weekend
Old Jun 14, 2010 | 11:04 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
That you know of. Having air in the system does more than cause the car to overheat. It also cause's cavitation which is the number one killer in a cooling system. When people see evidence of cavitation it is often mistaken for electrolysis. Simply jacking the car up will not eliminate all the little air pockets that form through out the block. OP follow the service manual procedure and use the bleeder.
Old Jun 14, 2010 | 03:43 PM
You should do it ASAP, it only takes a few minutes, bolt is 10mm and just have a jug of coolant ready.
Old Jun 14, 2010 | 05:35 PM
Kronn 98SH's Avatar
One more piece of advice. Don't buy the 50/50 mix. Just purchase straight antifreeze and mix it yourself.
Old Jun 14, 2010 | 07:51 PM
jlude90's Avatar
Hooray for adding water and saving lots of money!
and I fill the radiator all the way up and put the cap on and let it overflow into the reservoir, then after the thermostat is open just crack the bleeder screw and be done. No problems in FL on stock or aftermarket radiators, and also the procedure I use on our high HP evos at my shop with half core radiators that DD, except they don't even have a bleeder screw.
Old Jun 15, 2010 | 11:42 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
The 50/50 mix is a safer bet than doing it yourself. There is no water currently on the market thats meets any manufactuers specification. (Although distilled comes close) Also the safest bet is to use Honda Coolant.
Old Jun 15, 2010 | 12:16 PM
whitehill89's Avatar
I have a 95 Odyssey. I want to do a drain and fill. But I can't find the darn thermostat housing which has the coolant bleed screw. Can somebody tell me where I can get a diagram or layout of a 95 Odyssey engine? Thanks!
B18c1vicrx
May 13, 2009 01:01 PM
corince06
Jun 11, 2008 12:48 PM
dhn
23
Jan 5, 2008 01:06 AM
OutLuDeD
Jul 25, 2003 10:59 PM
drumsy
Sep 12, 2002 07:14 AM
