Old Mar 25, 2015, 10:53 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
changing thermostat
Old Jun 13, 2010 | 01:09 PM
redd357's Avatar
Default changing thermostat
Is the t-stat easy to change. My wife 2002 honda accord ex is overheating. I really dont want to take it to a mechanic if i could do it myself.
Old Jun 13, 2010 | 01:16 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: changing thermostat
easy
http://www.autozone.com/autozone/rep...96b43f803751e1
Old Jun 13, 2010 | 01:18 PM
ThatsMyEG's Avatar
yes it's very easy 2bolts and a couple hoses. Get the thermostat, the rubber gasket and some sealant. probably will cost less than 12 dollars for everything.
Old Jun 13, 2010 | 02:18 PM
nus_dogg's Avatar
Did you correctly diagnose to blame the T-Stat though? What if it didn't fix the problem after you replaced the T-Stat?
Did you make sure that the passenger side fan(radiator fan) is working like it should? It could be a bad coolant sensor, radiator cap, fan motor, fan circuit + fuse, faulty radiator, etc.
But yes, the T-Stat is easy.
Old Jun 14, 2010 | 08:03 AM
sgraham01's Avatar
If you do decide that the stat is bad and replace it yourself, place it in a small pot of water on the stove (without the seal on it- you could melt the seal if it touches the bottom of the pot) and boil the water to make sure the stat opens correctly before you install it.
Also, position the new one exactly like the stock one is positioned in the housing with the weep hole in the right place, at the top i believe.
Old Jun 22, 2010 | 03:38 PM
redd357's Avatar
Thanks for all the help change out the t stat, every thing works fine. Now I just got to figure out how to keep my wife from trading paint on th I-410.
woob87
Feb 27, 2018 04:28 AM
woob87
Feb 26, 2018 10:30 PM
hmtcrxsir
Apr 29, 2009 06:48 PM
rasinhell
May 24, 2005 06:05 PM
hitop
Jan 16, 2003 03:38 PM
