Newbie from Scotland attempting Mini-Me and needing help!
Old Jun 13, 2010 | 04:36 AM
StanleyScotland's Avatar
Default Newbie from Scotland attempting Mini-Me and needing help!
Hey folks.
Stan here from Scotland, needing a bit of help with my EJ6 1997 Civic Coupe.
It currently has a D16Y7, but i have a JDM D15B sitting here with a shot bottom end.
I have ECU and loom from the D15B.
I going to attempt a mini-me swap, but just have a couple questions....
Which ECU will i use? (Will the P08 JDM D15B ECU work? - And will it plug in and at least run?)
I gather my EJ6 will be OBDII (as it is a 1997), is this correct?
Any more help would be greatly appriciated
Old Jun 13, 2010 | 09:52 AM
mark11017's Avatar
Default Re: Newbie from Scotland attempting Mini-Me and needing help!
you will need an obd1-obd2a jumper harness to run that ecu. found at pherable.net or rywire.com. you need to use the stock harness for that car because 96-00 civic have 1 piece harness were as obd1 civic use 2 piece. good luck
Old Jun 13, 2010 | 10:01 AM
HondaPartsHero's Avatar
Technical Hero
unless you swap intake manifolds you are going to have to wire up the 2 wire IACV as the Y7 has a 3 wire. Also you'll be going from a 4 wire O2 to a 1 wire O2. The easiest thing would be just use the exhaust manifold from your Y7 as well and you won't need to wire anything for the O2.
xesvuli420
Aug 7, 2013 07:39 AM
turboef90
Dec 25, 2007 10:00 AM
dogfood
Jun 5, 2004 12:03 AM
89dohcEF
20
Dec 7, 2003 02:07 AM
