Need a power window and floor harness wiring diagram for 96-00 civic
Okay, I'm converting my 98 hatch from manual to power windows. I have the floor harness from a 96-98 civic EX. For some reason the drivers side window goes up and down fine. The passenger side went down, but will not go up. It is like it doesn't get power to the motor when you lift the switch up to raise the window. I tried replacing the passenger side window switch and that didn't work. I tried the drivers side and that didn't work. So, today I disconnected the harness from where the floor harness connects to the harness in the door. I was looking at the wires in end of the floor harness and I can see where one wire has been removed. I tried to trace it back to see where it was cut but the wire is completely gone. I need some sort of diagram or pictures of the wires going into that plug to see what wire I'm missing. Any help will be GREATLY appreciated. I'll try to take pictures of what I'm talking about later if there is any confusion of what I'm talking about...
Thanks guys!
Thanks guys!
i also am looking for a floor harness pin layout diagram but for a four door i have looked into the helms service manual and have not found it
i_ridedumped
141
Jul 25, 2014 07:01 PM
dfx3232
May 5, 2007 07:13 PM
