AP1 - F20C Complete Longblock 78k miles
I ended up putting in a F22C because this motor may have an issue. Let me start off first saying that this motor DOES RUN and it runs well. I have multiple vouches to say how this motor performed. I did a compression test / leakdown test and they werent the numbers I was looking for to make the power I wanted for a turbo setup. The motor was taken out 5/20/2010 by S&M Automotive, Richmond VA.
Cylinders
1- 210 psi / 34 % leakdown
2 - 205 psi / 25 % leakdown
3 - 235 psi / 15 % leakdown
4 - 235 psi / 7% leakdown
All leakdown results were still within the green / normal of the gauge but im not sure as to what is actually within Honda spec. I was told +/- 28% so this would mean its still straight. The leakdown tests show the head to be perfect with no issue, so it would be in the bottom end.
I say again, this motor does indeed run, doesnt smoke, and runs well. For someone looking to rebuild this motor it will be great, but for someone wanting a direct swap, you might wanna pull the head and inspect the bottom end. Two shops will vouch for the condition of this motor. it may just need some new rings and you're set to go.
Unlimited Auto Care Virginia beach - Pete
S&M Automotive Richmond VA - Bobby
Motor still has the pulleys, crank wheel, water pump, oil pump, brand new oil pan.
New price is $1,300 I WILL NOT accept trades, but I will entertain serious non low balling offers. PM, text or Call 904-422-6402.
Cylinders
Randysi
11
Jun 27, 2011 06:12 AM
mynameizstitch
May 19, 2009 07:52 AM
B18EG6
Jan 29, 2006 02:24 AM
