code 3 map sensor ?
okay here is the sisutation that i am having i washed my car one day really thoughly one day and i guess i got water where i was not suppose to cause my car started up really rough sense then. well i got the car to run right after i ended up replacing the coil with an extra on that i had laying around not sure if it was the true problem but the car ran better than it did before oh and i replace the spark plugs i just warranty them out lol. But back to the problem that i am having my check engine light is one and gives me code 3 which is map sensor i have swapped out with three different ones and nothing happens still get the same code even after trying to reset the ecu. Also when the car starts at first it will start but it hesitates almost like its going to die then it catches and as it catches the check engine light comes on also the car is running really rich as the air fuel gauge tells me plus you can smell the fuel and it does not idle normal either always sucking in alot of air and stay at 1000rpm. any help would be appericated i have checked over everything twice and i am at a lost at this point what it could be it only started this after i washed the car but everything thing else is running fine now.
Bswapped
Jun 20, 2015 02:22 PM
chucky86
Oct 13, 2011 02:46 PM
se93
Oct 7, 2002 07:00 PM
