1993 ej1 alternator or voltage problem
Old Jun 11, 2010 | 02:24 PM
atom1904's Avatar
Default 1993 ej1 alternator or voltage problem
hello all
i recently installed a hid kit from ebay, and now have a alternator problem
first the hid kit crapped out on me after couple of weeks of using it.
then i take out the alternator and get it tested and says that the unit passes, then i put the unit back and i get the same problem. then while with the alternator put back in i get it tested at a local parts store. the meter reads that the alternator is not giving any power to the battery. thats the first problem
second i pick up a new alternator and get it installed, and the new unit squeaks non stop, its not the OEM alternator but is for the honda civic. i'm out of answer and have a fat headache. i need some help please
Old Jun 11, 2010 | 02:29 PM
gga_bliss's Avatar
Default Re: 1993 ej1 alternator or voltage problem
Did you install the alternator yourself? If it squeeks, then it might be because of the belt? if it's the alternator, then return it and get another one.
Old Jun 11, 2010 | 03:58 PM
atom1904's Avatar
yea i did it myself, its kinda simple but very odd that this time around there is a squeak that is major annoying, i'm thinkin its the alternator but when its taken off and hand spun it doesn't make seem the squeak
Old Jun 12, 2010 | 12:12 AM
civicsmoke's Avatar
are you sure that the belt is tightened properly? loose belts can squeel
EJ8_Man
May 25, 2019 10:21 PM
ITR198
Honda S2000
Jun 18, 2008 04:13 AM
92silude
Mar 14, 2005 09:29 AM
iammrhand
May 12, 2003 10:53 AM
