Transmission & Drivetrain Gearboxes, Differentials, Clutches
bearing help
Old Jun 11, 2010 | 12:10 PM
rustanghunter's Avatar
Default bearing help
how do i pull the input shaft bearing when it disintegrated so a bearing puller cant get a hold of it?
this is whats left
Old Jun 11, 2010 | 02:17 PM
Honda Bull's Avatar
Default Re: bearing help
Freeze the entire casing to try and get the metals to shrink a bit, and get some hammers, screw drivers, pry bars, and blocks of wood out. I have yet to have a bearing puller work on that. ISBs that fall apart like that are my nightmare. lol
You can get a dremel/cut-off wheel out, too. Just avoid damaging the casing.
Old Jun 11, 2010 | 07:29 PM
David @ Synchrotech's Avatar
Heat the case around the bearing with a propane torch and use a slide hammer puller.
parahelium
Jun 8, 2017 10:46 AM
ldyer1994
Apr 23, 2015 08:19 AM
CivicVX94
Oct 15, 2007 05:42 PM
crzyfool24
Aug 21, 2004 03:09 AM
