How do I swap a an OBD2 engine into an OBD1 car????
Old Sep 13, 2002 | 01:00 PM
TURBOED-TEG's Avatar
Default How do I swap a an OBD2 engine into an OBD1 car????
I have a 95 Civic (EG) obd1 and plan on swapping in a 97 B18B LS obd2 engine into it. What all is required to do this swap?
Old Sep 13, 2002 | 01:25 PM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: How do I swap a an OBD2 engine into an OBD1 car???? (TURBOED-TEG)
Everything that is required for a normal swap. The ECU will be the only problem. Get a rechipped P28 and you should be good to go.
Old Sep 13, 2002 | 01:40 PM
Default Re: How do I swap a an OBD2 engine into an OBD1 car???? (Apex i ITR)
Will it still be OBD2 or will it be OBD1 with the new ECU. Also do I need to swap distributors and such. Can you give me a complete list of what is needed?
Old Sep 13, 2002 | 02:23 PM
CivicNewbie's Avatar
You don't need anything beside an OBD1 LS ECU.
Everything just plugs right in. You will need to use the engine wiring harness that comes with the B18B engine.
It will be OBDI with OBDII components (ie, fuel injectors, distributor, alternator ...)
Old Sep 13, 2002 | 02:40 PM
Default Re: How do I swap a an OBD2 engine into an OBD1 car???? (CivicNewbie)
bump
That is it huh...It seems like there should be more, but OK
Old Sep 14, 2002 | 06:10 AM
ttt
Old Sep 16, 2002 | 01:20 PM
yaya's Avatar
https://honda-tech.com/zerothread?id=278639 this is basicaly the same thing, but this guy doesnt know what he wants....just read it ...it should help
Old Sep 17, 2002 | 05:05 AM
92sleepR's Avatar
New User
Uhhhhh. With a crane?
Really, its totally plug and play. Just use an OBD1 computer and you are good to go.
Mike
EG_SINZ
14
Dec 12, 2011 03:23 PM
tealchief
Jul 9, 2009 02:08 PM
VTECyoda
Oct 29, 2003 07:47 AM
lowexr
Jul 2, 2003 01:07 PM
