B16 Build what cam?
Old Jun 10, 2010 | 06:30 PM
JDMEMone's Avatar
Default B16 Build what cam?
Hi everyone, I have a question for you what is your recomendation on cam choice? and also whats the largest cam I can use with out replacing the LMA's? My build list is....
B16a2 block with PR3 pistons (hastings rings)
Bottom end is ballanced with ACL bearings (all Green)
Mugen pan
Toda Flywheel
ported PR3-3 head
Supertech springs max lift 14mm and retainers
Type R intake valves
PR3 or P30 ported intake mani for testing
Type R TB
Toda header with 2.5 exhaust
Tuned with Neptune
The engine will be strictly for road racing
Thank you!
Old Jun 10, 2010 | 06:36 PM
BigBlock22's Avatar
Default Re: B16 Build what cam?
pro1's or blox b's would be my best guess for your build
Old Jun 10, 2010 | 07:54 PM
victor.ek4's Avatar
If it's a road race build, I'd tak to buddyclub.
I'VE HEARD (not sure about this information) that their spec 6 cam, is actually a cam for a 1.6L.
CHeck also the japanese manufacturers, they build parts for road race engines, not a 12s shooter.
either way, the Blox B's would be good cams, I have them, and like them
Old Jun 11, 2010 | 01:35 PM
JDMEMone's Avatar
The Pro 1's are what i was thinking of doing, my biggest question is can I run Pro 1's on stock PR3-3 LMA's?
Old Jun 11, 2010 | 03:55 PM
rhd_sir2's Avatar
You be fine running Pro 1 as long as you run the appropriate valve springs and retainers
Im running pro2s on my original LMAs with no issues at all
Old Jun 11, 2010 | 06:30 PM
JDMEMone's Avatar
Would Supertech springs more then adaquate?
Old Jun 12, 2010 | 02:44 PM
nus_dogg's Avatar
Supertech has two types of valve springs, so you have to know which one to pick. I'd go Pro Series valve springs if you're going with the Pro1s.
Pro1 or Tuner Stage 2 cams will do.
Old Jun 12, 2010 | 05:23 PM
o-man's Avatar
From: living too close to Karl, everythings busted, nc
I've got Pro 1's in my CRX I use to instruct at DE events. Lumpy idle, but seem to make power to 9k rpms. Using stock lma's I do believe.
Old Jun 12, 2010 | 05:30 PM
r.etheridge's Avatar
pro one's are awesome! like o-man said, a rough idle but they make really good power for the B16A
Old Jun 12, 2010 | 06:04 PM
JDMEMone's Avatar
Thanks boys! I just picked up a brand new set of Pro 1's for 450! I know that Supertech has two times the 14mm lift ones and the 15mm should I just go with the 14mm?
Old Jun 14, 2010 | 07:56 PM
JDMEMone's Avatar
Anyone recamend what springs from Supertech to use?
1988montecarlos
11
Jan 26, 2014 05:14 PM
bobby_da6
Sep 12, 2007 03:00 PM
blykins
52
Nov 5, 2004 10:40 PM
Edw-R
Sep 11, 2004 11:07 AM
Maxi
Nov 9, 2001 10:37 AM
