low torque numbers for h22!!!!!??? whats to do
hey whats up i just got my car tuned and made
206hp & 146tq bone stock h22a long block just bolt ons
camp1320 headers
skunk 2 mani
70mm throttle body
stock fuel pressure
stock pump
stock maxed out injectors
im running a 3" exhaust no rez no cat and im wondering cause im torque is sooo low what should i do??? cause to me that seems low
i mean im going to get cams soon and so on but for now that number is low as f*ck.
update:
retuned and mad 155ft just messin with the fuel and some timing.
camp1320 headers
skunk 2 mani
70mm throttle body
stock fuel pressure
stock pump
update:
its not your exhaust. possibly tuner error. it would help if you could post a dyno graph with the A/F ratio to go with it. no adjustable cam gears? its off by 10ft/lbs of torque at the most.... most folks averaging just over 200whp will get around 155-160ft/lbs of torque
well the skunk 2 intake manifold is a high rpm intake so i would say that my be the problem
it's like putting crower 3's in ur car top end but know bottom end.
All the bolt ons that u have say hi rpm hp full race u don't have any parts that scream for torque. And acutally u really are not that far off. I made 153 tq with a h22a1 i/h/e dc header stock intake manifold and 70mm tb with 2.5 exahust.
U are ok it's just the intake manifold and those big runners i'm pretty sure it's making the ports lazy for incoming air.
h23v you make a good point. he's probably better off with the stock manifold port matched to a 68mm TB. OP, what i dont understand is why you bothered tuning the car on that current setup? after market cams would've really helped and made the trip to get it tuned worth while
i really think its that manifold also.
stock jdm h22a
private label manufacturing headers
2.5" mandrel bent exhaust, no cat not res, just vibrant flat black
and a coild air intake
stock h22 base map
i made 187hp and 155 torque. those h22 intake helps make that torque.
stock jdm h22a
stock h22 base map
yeaa thanks guys i kinda figured that. Can having stock injectors and fuel pump do it, i mean ill post up my dyno graph as soon as i get a chance.
My A/F was 13.48 at 7,800, he told me my injectors are MAXED out so would it hurt to put in a set and a 190 fuel pump??? im goin to be buying cams soon so all the bolt on's will def complement them very nicely.
i lv the top end cause i was always building b series and there known for that, but this is my first h2b or h22 and i lv keepin up side by side with k's with a simple set up like mine.
yea there maxed out. Alouta tuners are seein with a set of 440dsm injectors on a stock h22a motor, with bolt on's there making more power, dyno proven. Im just gonna buy a set anyways for the cams i choose to get.
everyone is right about the long intake runners and big piping on the low torque reason.
either you dont have H series injectors, or your tuner is lying to you.
they are not maxed out on a stock motor w/ bolt-ons
i have made 275whp on stock injectors @ 80% in the past
and its not the long runner length thats hurting your tq
it would be the large plenum and tb instead...
________
Dodge v. ford motor company history
Cams and compression... larger intake mani and TB on stock cams... If you had stock intake manifold and TB I would imagine you would pick up some torque... cams...
CapnToll
10
Oct 2, 2007 03:40 PM
