PICTURES... HELP ME FIX THIS OVER BOOST ISSUE
Old Jun 10, 2010 | 05:22 PM
lsvtechatch92's Avatar
Default PICTURES... HELP ME FIX THIS OVER BOOST ISSUE
THIS IS HOW THE MANIFOLD WAS BEFORE AND WITH A 7 PSI SPRING I WOULD HIT 16LBS @ 9K IN 3RD GEAR AND 18 PSI AT ABOUT 8500 IN FOURTH WITH A BIGGER SPRING 10-14 IT WOULD HIT 16LBS ALOT FASTER
WASTEGATE OFF AND HOLE IN MANIFOLD LIKE THIS IT BOOST 0 PSI ALL THE WAY TO ABOUT 6500 THEN SLOWLY BUILDS UP TO ABOUT 6 PSI @8600 RPM THIS IS ON PUMP GAS
I WOULD LIKE THE CAR TO RUN NO MORE THAN 15 PSI ON PUMP GAS ANY SUGGESTION ON HOW TO REDO THE NEW WASTEGATE USING THE EXISTING HOLE... I FIGURED CUT IT AT A ANGLE (STRAIGHT PIECE) AND WELD IT ON SO THE AIR FLOWS RIGHT INTO IT?
sorry about the caps guys just realized lol... let me know what yall think... if i could get it to hold lower boost that would be great this is a 46mm wastegate from precision and a precision 6262 my goal is to be able to run like a 9 psi spring or so and be able to hold that boost with the smaller spring it spools slower ;( car was tuned at 14.5 psi motor is fully built
thanks in advance
Old Jun 10, 2010 | 09:53 PM
JERL 108's Avatar
Default Re: PICTURES... HELP ME FIX THIS OVER BOOST ISSUE
Old Jun 10, 2010 | 11:12 PM
88ED8's Avatar
Originally Posted by JERL 108
Old Jun 11, 2010 | 12:55 AM
king06's Avatar
Ok, so to get things straight, with absolutely no gate and a hole in the manifold and it still made boost?
Old Jun 11, 2010 | 04:45 AM
Poootie's Avatar
you took the gate tube off(to see if it would still make boost, and it did? :-O. or it broke??
i'm soo lost right now!
Old Jun 11, 2010 | 05:27 AM
Turbo-charged's Avatar
put 2 gates on it, problem solved.
Old Jun 11, 2010 | 06:02 AM
kyden's Avatar
what size gate is the hole for? i'm sure a 60mm would do the trick, lol.
Old Jun 11, 2010 | 06:15 AM
tony1's Avatar
Looks like it broke, you can't really cut a tube off and make it look like that. That's an interesting way to figure out if it's a wastegate problem. lol
Old Jun 11, 2010 | 06:49 AM
Honda Bull's Avatar
Definitely looks like that broke off. Two wastegates or one big *** 60mm would do the trick.
BTW, does your tuner know of this? lol
LMAO! Indeed.
Old Jun 11, 2010 | 07:15 AM
d112crzy's Avatar
Old Jun 11, 2010 | 07:33 AM
tony1's Avatar
I do now! lol Now maybe he'll belive me that he needs a bigger gate.
Old Jun 11, 2010 | 07:47 AM
Honda Bull's Avatar
^ Hahahahahah! Oh, jeez.
Old Jun 11, 2010 | 09:08 AM
boostek9's Avatar
sounds like a easy fix, bigger wastegate or dual 38s
why would he not believe you, lol
Old Jun 11, 2010 | 10:05 AM
Poootie's Avatar
lol, i figured it broke. But i was soo mindfaked by the OP post that i had to cover all grounds!
lmaoooooooooo!
Old Jun 11, 2010 | 11:01 AM
92redhatch's Avatar
Its seems like all these billet turbos have creep issues. I had my 6765 creep to 18psi with a 7psi spring. I added another wastegate so hopefully that issue is solved.
Old Jun 11, 2010 | 11:59 AM
Mr. Em1's Avatar
nice manifold!
Old Jun 11, 2010 | 12:49 PM
Honda Bull's Avatar
What was your engine and manifold/WG setup?
Old Jun 11, 2010 | 04:59 PM
92redhatch's Avatar
84x89mm lsvtec topmount single 38
now dual 38's
Old Jun 11, 2010 | 05:33 PM
ok manifold had a small crack and i let it heat up and worked it back and forth and broke it off... it hit 6 psi at 8800 rpms like this but didnt make any boost till 7200 or so... i cant afford a bigger gate right now .... i may sell the manifold go top mount and twin 38 mvs that way i can get my 3 pc front end i want .... this would take some time to save for but i really want the 3 pc front end... i would like to get this to where i could at least have fun with the car for a little bit... anything i can do with what i currently have? im gonna try to make it work with twhat i have
Old Jun 11, 2010 | 05:34 PM
i beleived you the whole time lol... i had just bought this one from you on my previous trip to fix the same issue ha ha.. fml
Old Jun 11, 2010 | 10:31 PM
Honda Bull's Avatar
Okay. So it had nothing to do with it being a billet wheel'd turbo. You have a larger turbo, on an efficient engine and setup, trying to regulate a lot of exhaust through a small 38mm wg down to 7 psi. Not gonna happen, I'm afraid. :p The twin 38's should work well enough for you.
Old Jun 11, 2010 | 10:43 PM
jlude90's Avatar
Its amazing the things customers don't believe you about.
Old Jun 12, 2010 | 11:04 AM
i do beleive him lmao
Old Jun 12, 2010 | 06:52 PM
kmaz93da's Avatar
i had same problem with sls topmount and s362 tryen run 10psi on 44mmgate it would creep to boostcut at 18psi. Now i took manifold off for 4th time after trying add teardrop and bought new 44mm gate, finaly had local shop cut off 44mm and add dual 38mvs gates(10psi springs), still creeps to 12psi but Holds at 12psi to revlimiter in every gear, its just too much pressure trying to bleed off at low psi, i say you get dual 44 if u can fit them
Urinemachine
May 12, 2010 01:53 PM
odishaw
Apr 1, 2008 04:37 AM
afrothunda713
Jul 10, 2006 09:40 AM
pushinlsteg
Nov 27, 2004 01:28 AM
BB6-213
Jun 10, 2004 05:08 AM
