wtf is this thing on my block?
hey i had the motor out of my car and I was lookin at it and noticed like 4 big 19mm plugs. I took one out and found a buncha metal shavings (motor was toasted, no big deal) but..
wtf is this plug thing and what purpose does it serve?
looks like a cleanout for the cooling system. kinda odd.
lol
looks like a freeze plug,
thats were your coolant runs,
idk if its actualy called a freeze plug tho, cause Freeze plugs ive seen are pressed in not tapped, but those were on v8s
ps your motor looks extremly dirty, i wouldnt have gotton my tools near that thing...
lol jk sucks the motors gone tho
replies make sense, thanks for the shouts. yeh the motor is toasted, so don't worry about the metal shavings. I doubt they'd be in there if the motor was still good.
on the front side near the transmission right..? that's where the block heater accessory is installed for colder climates. it replaces that plug and has a wire that you plug in to a standard wall outlet for power.
only reason i know is because i bought a motor that had one installed. no one needs a block heater in SC.. haha.
yeh a block heater, that's the kind of complex answer i was lookin for. a cleanout for the cooling system is too boring and uneventful.
thanks for the shout.
its a core plug. it where they get the material out when they cast it. the block heater is made to go in it. just like other core plugs/freeze plugs.
digital sol
Welding / Fabrication
Jun 26, 2007 10:35 AM
quick1racer
Feb 6, 2004 01:20 PM
