2000 Civic SI OBD2b to OBD1 AC Clutch problem
Old Jun 10, 2010 | 09:28 AM
kywnichoEM1's Avatar
Default 2000 Civic SI OBD2b to OBD1 AC Clutch problem
Ok I hope someone on here can help me with this problem. I have a 2000 Civic SI with a B16a SIRII motor swapped in. I have the original OBD2b harness that plugs into my jumper harness and terminates at the P30 ECU. My problem is the AC clutch will not engage. Now this is what I have done:
Checked all fuses according to the troubleshooting section of the factory manual. Verified my Compressor clutch relay is working. Checked for continuity between Underhood fuse box and A17 and A15(obd2b to obd1 pinout for ACC signal) My condenser fan kicks on and stays on when the AC button and fan are turnded on. My pressure switch is closed indicating good pressure. I also put a Freon gage and it looks good. I jumpered pins 1 and 2 of the compressor clutch relay socket and I can here the compressor clutch click. I checked for continuity from the relay socket to the compressor clutch connector. Here's the weird part. When an OBD2b computer is plugged in the AC works fine. Blows ice cold air. So I looked in the schematics. I found that on a stock computer setup the a NPN transistor switches a ground connection and that engages the coil on the ACC relay. If you look at a OBD1 schematic from a 92-95 civic, It looks like the ACC gets it's ground from a double pole Ac Switch. So does that mean the obd1 is incapable of shunting my ACC ground to complete the circuit? Any suggestions out there. I guess I'm not the only one who's done this to their car.
Old Jun 18, 2010 | 11:12 AM
Default Re: 2000 Civic SI OBD2b to OBD1 AC Clutch problem
Ok for anyone out there who will have or has had this problem. I found the ground comes from the AC switch for the OBD1 computer. Because my wiring harness is looking for the ground at the OBD2B ECU, my clutch never kicks in. I'm going to re-wire my ac system just like the obd1 civic. If anyone needs help just message me I can provide schematics and instructions on how to rewire the system.
Old Feb 27, 2011 | 05:48 PM
Eyemax1024's Avatar
Icon2 Re: 2000 Civic SI OBD2b to OBD1 AC Clutch problem
I have a problem with my obd1 a/c circuitery, the npn transistor is always supplying ground to the clutch relay. I can't find an spare transistor qm3, but i got the datasheet, but I can't understand the function of the avalanche diode, also there's not spec for the diode. I need to see your rewire so i can fix or build a transistor.
Thanks
Old Feb 27, 2011 | 05:53 PM
Former User's Avatar
Thanks
Why not just replace the ECU?
Old Jun 7, 2020 | 04:19 PM
Justin Ortiz's Avatar
would it be possible for you to share those schematics? im a decade late but i am having the exact same issue.
Old Jun 7, 2020 | 05:45 PM
muellersfan's Avatar
10 yr old thread
DieMaster
19
May 26, 2024 05:10 PM
alextech
Honda Civic (2006 - 2015)
Mar 27, 2018 10:30 PM
d-ramey
Acura TSX
May 23, 2014 05:47 PM
cncgod
12
May 31, 2011 06:35 PM
sk8er602
May 22, 2007 07:25 PM
