somethings wrong here.
Old Jun 9, 2010 | 09:59 PM
teamjdm239's Avatar
Default somethings wrong here.
ok, so my friend has a b18a1 in his da. hes been complaining to me about problems he's having since he traded his dc for this piece of junk.
now heres the issue. the motor is on timing,sounds like theres valve knock.
he has a ls head, with a 1 layer headgasket unmilled.
he tried another head, with the same headgasket, and still the same sound.
he claims that the guy who put the ls in the da before he traded for it, put gsr rods, and pistons, on a ls crank, in the ls block, with a 1 layer gasket.
now i did some research, and found out that the gsr rods, are longer then the ls rods. so that would mean the piston to deck height is negative, correct? (pistons are poking out the top of the block) i told him to swap out the rods, and pistons, and see if he has the same issue, but i could be wrong...
Old Jun 10, 2010 | 06:27 AM
killerpenguin21's Avatar
Default Re: somethings wrong here.
why dont you try an oem gasket?
Old Jun 10, 2010 | 06:39 AM
negusjuda's Avatar
with that set up your buddies compression would be 12.3:1 and have a negative piston to deck height of -0.024 how that motor even runs i have no clue lol and those numbers and compression is with a oem 3 layer head gasket
http://www.zealautowerks.com/bseries.html
check out this compression calculator
Old Jun 10, 2010 | 10:26 AM
nus_dogg's Avatar
I would go with a Honda 3 layer HG like mentioned above.
Old Jun 10, 2010 | 12:10 PM
EG1834's Avatar
How thick is the head gasket? From what I gather, the piston is sticking up out of the bore roughly .050" (or ~1.2mm).
Old Jun 10, 2010 | 12:26 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
so when he tried the other head did he look to see if it had p72's in it? lol
also did any one try a valve adjustment. we need some more info here to help you.
kuhwahh
Mar 11, 2011 11:51 AM
fv8s
17
Jul 9, 2010 12:25 PM
98GSR-Turbo
Oct 14, 2008 09:22 AM
GSE980
Jul 7, 2006 02:54 PM
tfalconier
Aug 18, 2004 07:56 PM
