SOMETHING IS WRONG WITH MY BRAKES?
Old Jun 9, 2010 | 03:15 PM
91GEDHATCH's Avatar
Default SOMETHING IS WRONG WITH MY BRAKES?
So here is the quick story, its a 91 hatch, b18a1, when I bought the car the guy had put bigger brakes on the front and they worked great! Now when I accelerate they pull to the right, when I'm cruising steady it feels shaky like something is rubbing, then when I brake it pulls to the right pretty bad. Do I need new calipers? How do I tell if they are not releasing all the way or find out what is causing this. Worst of all, I can't remeber what specifically he said the brake setup was off of. Some kind of acura, pretty sure an integra. So here are pics, can anyone identify these and give me a little guidance in figuring this out? Thanks everyone!
Old Jun 9, 2010 | 03:45 PM
shawn_crx's Avatar
Default Re: SOMETHING IS WRONG WITH MY BRAKES?
Check your tires, aligments, and those studs are too long for your car....
You already got your wheel off the ground, spin the wheel to see if it spins freely(N).
Look like you could need a new set of brakes and turn your rotors.
Old Jun 9, 2010 | 03:49 PM
EHondaJDM's Avatar
What the hell did those lugs come off of..?.?...
Old Jun 9, 2010 | 04:03 PM
D16SiHatch's Avatar
well if the cars pulling on the right side then you should probably look at the passenger side not the driver side brakes lol
i suspect that one or both of the slides is frozen in the caliper. take the caliper off and see if they move. if not then you may have to try and break it loose with a hammer and maybe some wd40 or pb blaster. when my caliper froze up on me i had to use an oxy acetylene torch to heat it cherry red and then break the damn thing loose. hopefully it doesn't come to that for you.
also, check the rotor surface for flatness. if it's all muffed up then either replace or turn the rotors and install some new pads.
oh, and if i had to guess i'd imagine those knuckles/brakes are from a da integra. could be wrong though so maybe someone else can verify.
Old Jun 9, 2010 | 06:06 PM
91GEDHATCH's Avatar
The lugs are buddy club extended lugs. I don't care for them and don't need them, they are for running slicks on the front which i dont care to do. I appreciate the helpful input. The pics are from when I happened to have tires off, that is why it is of the drivers side but thanks for the critique! I'm about to put a new set of tires on so I will know if that's the issue but unless these tires are terrible, I've never had tires have this much sway before. I'll keep working at it.
Old Jun 9, 2010 | 11:29 PM
hatchet_honda's Avatar
wonder if the previous owner swapped the da master cylinder in too?...this is why i always start from scratch. i need me a car unmolested lol
Old Jun 9, 2010 | 11:59 PM
91GEDHATCH's Avatar
Yeah I know... but it was so tempting, all that work already done! I'll have to trace it down.
Old Jun 13, 2010 | 01:01 PM
91GEDHATCH's Avatar
Got new rims and tires, it helped a little bit?? It is still feeling like it's rubbing off and on still. Should I just get new caipers or does it sound like I need new rotors as well? Thanks!
Old Jun 13, 2010 | 01:43 PM
netfreak's Avatar
Maybe try the brake lines to the caliper first. I had one caliper on my old firebird grabbing pretty much all the time, turned out the line was worn out and the fluid couldn't escape the caliper.
Old Jun 13, 2010 | 02:11 PM
B16-CRX's Avatar
Make sure the caliper slider bolts are lubed well and move freely. They have the ribbed rubber covers. Had the same prob with integra brakes on the front of my crx
Old Jun 13, 2010 | 08:30 PM
91GEDHATCH's Avatar
Awesome, I will check that out tomorrow hopefully. I really just want this problem to go away!
patrickstar
Suspension & Brakes
Apr 24, 2009 12:41 PM
JDM_SOHC
Mar 23, 2006 05:11 PM
lakers6902
Jun 3, 2004 08:35 PM
tonyhondaracing
Jul 20, 2001 03:23 PM
