camber ? need some help
Old Sep 13, 2002 | 10:45 AM
GsR HtCh's Avatar
Default camber ? need some help
i have a 98 civic dx hatch and i just failed inspection for bad camber. just wondering what everyones opinion is on the sprint camber kit. anyone else have any opinions on what to do. i looked at it and its pretty bad.
//==0==\\
[Modified by 98civichtchback, 7:46 PM 9/13/2002]
Old Sep 13, 2002 | 10:47 AM
Ricky Rojales's Avatar
Default Re: camber ? need some help (98civichtchback)
They work fine. I've used them and they're just like the Ingalls kit.
Old Sep 13, 2002 | 10:51 AM
GsR HtCh's Avatar
Default Re: camber ? need some help (P)
i think im gonna pick one up soon. i raise up the suspension for now.
Old Sep 17, 2002 | 04:50 AM
GsR HtCh's Avatar
how are specialty. do they make good stuff??
Old Sep 17, 2002 | 05:18 AM
CXHatchback's Avatar
Skunk2
Old Sep 17, 2002 | 08:32 AM
Speciallty fronts work by adjusting a rotataing center with an offset hole for the bolts that attach to the upper A-arm. I don't like how this adjusts. It can work but it's possible for the center to rotate out of position. And the range is limited.
Get the Ingalls or Sprint fronts instead. This offers a greater range of adjustability and is easier to adjust.
As far as SKUNK2s go they're OK except that some users have experienced the bolts having an inability to hold the camber properly during aggressive usage. This can be fixed by changing out the bolts (the originals used allen heads) and roughing up or indenting the surface (with a dremel) where the bolts are tightened down upon, to improve the "bite".
The rear Specialty kits also work with an offset. I'd go with the washer trick however, since it does the same thing and cost only pennies.
[Modified by P, 12:34 PM 9/17/2002]
Old Sep 17, 2002 | 09:14 AM
fuguman's Avatar
New User
you have a rwd civic?
i like the rear diferential =0=
Old Sep 17, 2002 | 03:49 PM
letholone's Avatar
how does that washer trick work? where do you put them. i have a 92 integra and the camber is only a litte off in the back and dont want to spend the chips for a kit.
thanks
ucd_4_life
Jan 31, 2006 04:15 PM
JDMek
Nov 21, 2002 12:16 PM
markben151
Sep 24, 2002 12:15 PM
shion
Jun 12, 2002 02:27 PM
fcuked
Jan 29, 2002 05:57 PM
