00 Prelude with H22A swap won't rev past 5000 RPM
Old Jun 8, 2010 | 05:27 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default 00 Prelude with H22A swap won't rev past 5000 RPM
The car SOMETIMES won't rev past 5k RPM. It also starts to run kinda weak before the issue starts happening...and then runs really weak while the issue is present. It seems to bog/not make the normal amount of power. But again...the car runs PERFECTLY normal most of the time.
-There is NO cel on.
-2000 prelude base version.
-It is a H22A swap (JDM). 5 Speed manual.
-Has the USDM external coil distributor.
-Runs fine most of the time.
I have tried searching for this. The threads either lead nowhere or the issue itself is different from mine.
I have tried replacing the distributor with a known good one. No change. The car runs fine when it wants to.
I've heard things about a bad CKP or CYP sensor. Does anyone have the testing procedure for these sensors? I don't have a manual for the car. I know I should buy one...but if someone could get me the resistance value or testing procedure in the mean time, it'd be great.
I actually sold the car to a friend before all this started happening. So needless to say, I feel very bad and want this issue resolved.
Thanks in advance for the help.
Old Jun 9, 2010 | 06:12 AM
ilikehonda's Avatar
Default Re: 00 Prelude with H22A swap won't rev past 5000 RPM
are you using an obdII ecu and engine?
Old Jun 9, 2010 | 06:03 PM
B serious's Avatar
Alright so I think the issue is resolved. I drove it around all day and discovered that it would rev past 5k if I wasn't going full throttle.
Long story short, it was the cat. It had broken apart inside and was clogging intermittently. I ran the car open header (so much fun) and it ran beautifully. So I hollowed out the cat. Easy fix. I told my friend to just buy a new cat when he gets a chance. Now what do I do with all these shiny platinum flakes all over my garage floor.....
Old Jun 9, 2010 | 07:04 PM
Enzo15's Avatar
Get the flakes and sell them They are worth a lot...
Old Jun 10, 2010 | 12:48 PM
nus_dogg's Avatar
Glad to hear you got taken care. I was gonna say that my buddy's H2B setup has a similar problem and it was a bad TPS, and I couldn't remember if he's got a code or not.
delsoldriver96
Oct 9, 2014 04:53 AM
mondiex
Jun 20, 2012 05:42 PM
amimaxima
Aug 24, 2011 07:14 PM
NukeeZoid
Nov 9, 2006 08:01 PM
ramikassab
Dec 20, 2004 12:57 PM
