B18C-R swap
Old Jun 8, 2010 | 09:39 AM
Zombie Nachos's Avatar
Default B18C-R swap
So...I'm currently prepping to do a B18C-R swap in my 94 EG. And was wondering which certain parts I need. I know I need the obvious B18C-R engine, tranny, ECU, B-series engine mounts, and OBD2 to OBD1 jumper wires. But as to which axles, half shaft, and shift linkage I have no clue. And if there is anything else that I'm missing please let me know. Anything will help me out right now! Thanx!!!
Old Jun 8, 2010 | 09:45 AM
jdmh22eg2's Avatar
Default Re: B18C-R swap
well main things other than what u listed are this for a eg swap to b
1. Dc teggy linkage
2. obd1 vtec harness for motor (can be wired in)
3. u need Dc axles and half shaft
4. 94-01 tegg 5spd rear T bracket
5. stock dc/eg mounts them selves or just buy hasport or avid mounts what ever ur budget is
think that is about it that i can remember ATM
Old Jun 8, 2010 | 10:46 AM
honda_luvr_2000's Avatar
Make sure you get a half shaft for a 5 speed B series and NOT an automatic. The auto will NOT fit with the 5spd trans. You can use the axles & half shaft from any of the following vehicles:
94-01 Integra (any model)
94-97 Del Sol VTEC (DOHC)
99-00 Civic Si (DOHC VTEC)
You can mix & match them from any of those cars. The axles can be from an automatic trans Integra, but the half shaft HAS to be from a 5spd trans.
The rear trans "T" mount bracket also can come from any of those above cars as long as if from an integra it's a 5spd.
Shift linkage from either a 94-01 Integra or 99-00 Civic Si (DOHC VTEC). You could not use the linkage from a Del Sol VTEC (DOHC) because it is different.
Torque mounts have to be off of a B-series. The D-series torque mounts will not bolt to the B-series block or trans.
Radiator & heater hoses from Del Sol VTEC (DOHC). Integra GS-R & Type-R radiator & heater hoses MAY fit the 92-95 Civic, but I can't remember for certain at this time.
It will be easier to use an OBD1 VTEC engine harness than trying to wire in an OBD2 engine harness.
slowDB7
Jul 30, 2013 10:34 PM
EurasiaSI
Oct 10, 2011 05:34 PM
nolanator6
Mar 2, 2011 03:17 PM
Lude-venom
Feb 8, 2009 09:52 PM
1 Fly SI
Oct 8, 2007 07:19 AM
