Humming again after bearing replacement...
Old Jun 7, 2010 | 07:12 PM
nemesis25's Avatar
Default Humming again after bearing replacement...
The front left wheel bearing was replaced a little while ago, on my 97 Prelude for a humming noise at around 50-65mph. The noise stopped but recently returned after about 8500 miles. I believe the shop removed an NTN and installed a NSK unit which I got from Honda. My question is, will Honda honor the 12 month/12000 mile warranty.
Old Jun 13, 2010 | 12:34 PM
miamijdmcoupe524's Avatar
Default Re: Humming again after bearing replacement...
i believe they will honor it if they installed it. Did you check to see if your tires need to be balanced or replaced??
Old Jun 13, 2010 | 02:31 PM
smackdown's Avatar
its loose they probably did not torque it down to specs. check the torque specs and re-torque.
Old Jun 13, 2010 | 04:39 PM
TheJGB3's Avatar
The front bearings are pressed in there is nothing to tighten.
Old Jun 14, 2010 | 10:59 AM
Honda Sport's Avatar
could possibly be other wheel bearings. I've seen this happen more then once.
Old Jun 14, 2010 | 11:11 AM
95 integra's Avatar
While correct, the outer race is pressed in the inner race is held together by the back of the axle and the axle nut on the front. Without the axle nut installed the inner race will push out.....ASE????
Old Jun 14, 2010 | 04:42 PM
nemesis25's Avatar
Tires were balanced recently. The noise is at the left wheel again. And as far as torque specs, I think an impact wrench was used to remove and installed everything.
Old Jun 16, 2010 | 12:13 AM
smackdown's Avatar
very well said
brah like i said just tighten the axle nut dont use the impact wrench use a cheater bar or a pipe extension .. lmk the results
Old Jun 17, 2010 | 08:52 AM
SKDRCR's Avatar
Put the car on a lift and drive the vehicle to at least 35mph. Have someone listen
with a stethascope to both knuckles. See if you hear the humming noise or any
difference between both wheels. Another way you can check it is to drive the car
on the road at the speed you hear the noise, then steer the car one direction and
then the other and see if the sound goes away then comes back. If you steer the wheel
to the left and hear the sound, it's probably the right side and vice versa.
Mr2u53
Jul 21, 2014 06:04 PM
eda6
Mar 11, 2014 01:40 PM
MrXclusivE
Mar 8, 2009 05:51 PM
nickpapa
Aug 27, 2007 03:43 AM
