civic wont start
did a search couldnt find an answer....fuel pump isnt getting power.....car cranks over all other things work, changed the relay checked the pump checked the grounds everything is checked just the pump isnt turning on so the car isnt getting fuel to start
If you replace the relay, turn on key, check for voltage at the pump, and if not voltage then you have bad relay/wires/fuse. Trace it back to the power source. If voltage at the pump then probably bad connection or fuel pump.
i checked the pump its fine, checked the grounds too....the main relay was clicking once so i changed it i had an integra one sitting around, same problem so i ordered the right one will be here tommorow we'll see
hondaluver12
Jan 30, 2012 02:37 PM
spencedogg
Aug 29, 2003 05:52 PM
