Eg4 & swaybars
Old Jun 7, 2010 | 06:20 AM
joprez's Avatar
Default Eg4 & swaybars
I would like to add some swaybars to an eg4.
does anyone know if eg4 supports them with endlinks and asr subframe just like the eg6?
Cause someone said me eg4 dont have the holes to atach the endlinks is this true?
Old Jun 7, 2010 | 07:15 AM
BlueIntegraBoy's Avatar
Default Re: Eg4 & swaybars
You can mount the ASR brace if you intend to run a larger rear sway bar. However, if you run the same size as the EG6, you won't need reinforcement. As far as the holes for the endlinks in the LCAs, you won't have them and will need to purchase OEM or aftermarket LCAs.
Old Jun 7, 2010 | 07:17 AM
joprez's Avatar
yes but how about the front swaybar?
Old Jun 7, 2010 | 08:06 AM
If the EG4 did not come with a front sway bar, then you will need front LCAs from an EG6 or Integra.
Jimmy
Suspension & Brakes
Nov 26, 2010 03:09 AM
rtuner
Suspension & Brakes
24
Aug 2, 2009 08:33 PM
Dr. Willy
Sep 2, 2008 05:26 PM
thegreat0ne
Aug 24, 2007 09:29 PM
GloomyX
Suspension & Brakes
18
Mar 29, 2007 07:42 AM
