Has this happened to anyone?....(I doubt it)
Old Sep 13, 2002 | 08:43 AM
*Boostwerks*'s Avatar
Default Has this happened to anyone?....(I doubt it)
I was driving back from school today, and tried to roll up my drivers sid window.....
At first it seemed like it was jammed....so I turned the window down a bit....and then the god damn glass just FELL out of the bracket!!!.....the glass fell down into the door....and it looks like I'm gonna have to remove the panal....
Am I going to need any special tools? How the hell do I even remove the panal?
Old Sep 13, 2002 | 08:52 AM
technine's Avatar
Default Re: Has this happened to anyone?....(I doubt it) (Bryson)
You have to remove all screws out of the door first, and I mean all screws... including the ones in the speaker panel that is inside the panel also (2 screws inside the grill). Then you can pop off the bottom of the panel first by pulling with some force to get the little tabs to pop out the door (you might break one or two tabs if you are not carefull). Then once all screw are removed and the little tabs are out of their sockets, pull up and back a little towards the rear of the door and it should slide up and out. Remember, remove all screws in the door... door handle, door lock and lever trim and more. HTH
Once you do it once... take you 1 minute to do it again.
96teggynonVtec
Feb 18, 2006 02:22 PM
206civic
Jan 8, 2005 11:43 AM
eddie1681
Feb 24, 2003 10:33 PM
serious
Sep 6, 2002 04:40 PM
teg95
May 22, 2002 01:16 PM
