Tial 44mm wastegate. Is this diaphragm ok to use?
Old Jun 6, 2010 | 06:20 PM
Mikey3000's Avatar
Default Tial 44mm wastegate. Is this diaphragm ok to use?
I took the top cover off to see what spring I had and noticed this. This is the first time I know of the cover being off. I bought the wastegate brand new and it's been on the car for 3 or 4 years now. I just want to know if I should get a new cup assy. From the looks of it, it doesn't look like it would leak.
Old Jun 6, 2010 | 07:00 PM
SPOOLINmatt's Avatar
Default Re: Tial 44mm wastegate. Is this diaphragm ok to use?
I bought 2 44mm wastegates 2 years ago and I took one apart to adjust the spring late last year and it HAD THE SAME EXACT THING. I was like WTF...but ive been running it since then without any issues, i used a flat head to peel it apart and then lubed it up to be able to slide the top cover over it very carefully. Its crazy because when i saw the title of this thread i started to contact tial to find out how much it would cost to get it rectified...funny that im seeing the same thing on someone elses wastegate.
Old Jun 7, 2010 | 02:14 AM
Mikey3000's Avatar
lol, that is crazy. i'm not able to pull it apart, it's probably bonded because it's been in that state for so long. datalogs show that boost is spiking about 3 psi over what the boost controller is set for, but i don't know if that is because of the diaphragm. it's most likely the wastegate placement.
Old Jun 7, 2010 | 08:38 AM
E85B18's Avatar
Bummer. I'd say youre fine unless there's a hole in it and leaking.
Old Jun 9, 2010 | 05:46 AM
TiAL's Avatar
post a pic of the under side after you peel it apart
Old Jun 9, 2010 | 09:44 AM
E85B18's Avatar
That looks like a defect. TiAL gives good support, if it gets damaged when you pull it apart I bet they'll give you a new one
Old Jun 9, 2010 | 09:58 AM
Mikey3000's Avatar
i wish... *hint hint, nudge, wink* to TiAL
TiAL - like I said in my 2nd post, i can't peel it apart. it's pretty much bonded like that now.
Old Jun 9, 2010 | 11:33 AM
TiAL's Avatar
just give it a good tug, it will come apart, don't be afraid to apply a little force
also what is the SN on the top?
Old Jun 9, 2010 | 02:22 PM
Got traction's Avatar
my 38mm was like that.
Old Jun 9, 2010 | 02:24 PM
E85B18's Avatar
Im surprised this is so common. For a quality gate...
Old Jun 9, 2010 | 02:27 PM
runsfromdacops's Avatar
y risk it? just buy a new one and vary carful when you put it back together
Old Jun 9, 2010 | 02:39 PM
cantaffordaccord's Avatar
I have a brand new 38mm gate thats still not used with this issue as well I took mine out to change springs I peeled it and put it back together with the new spring.
please let tial see this thread I can post pics if wanted. I would like to hear what there response is maybe we can get a new diphram replacement since it is a simple yet common factory defect?
Mr. Em1
Nov 4, 2008 12:04 PM
dont_tri
Jul 1, 2008 04:19 AM
HickamHatch
Oct 26, 2005 06:57 PM
PureTeg420
Dec 24, 2001 02:27 PM
