Need help CAr wont start..might be electrical?
Old Jun 6, 2010 | 03:31 PM
synical1's Avatar
Default Need help CAr wont start..might be electrical?
OK ok i have a 1993 honda Civic hatchback SI with a D16Z6 motor...WEll leme tell you the Story.... First my car was running fine i work a 12 hour shift 6pm-6am well... 6pm i went to work it cranked up fine started up drove to work. 6am time to get off i notice that my gas was low so i cranked it up it turned and it turned and im like DAm must have no gas .. i got gas in it filled it up half way .. start the car it turned over and turned over Im like WTF. so it dont work.... towed my car home i checked if i had a spark by checkin i took one spark plug out atttach to the sparkplug wire and place it on the chassis to se if it sparks when i crank. Still nothin no spark.. i go get a brand new distributor replaced it did the same method.. still no spark.. i notice also my main fuel relay wont clic when i have it on the on mode.. my chec engine also wont go off after a few second .. now i go get a new main fuel relay replaced it... the same problem that i been having is still the same.. to recap i have a new distributor got new spark plugs.. and wire.. baught a new fuel main relay.. So those i replaced Still no sparks.... Now what i think is THe ECU.. Waht do you think about that solution do u think it would solve my problem so it will Start up . and get spark. Need everyone help advice opinion on this i need the car to run.. THANKS.
if your opinion or advice is correct and it gets my car runnin i will pm the person wit the idea and get some info and i will pay them 50 bucs.
Old Jun 6, 2010 | 03:54 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: Need help CAr wont start..might be electrical?
http://techauto.awardspace.com/ignition.html
Old Jun 7, 2010 | 05:47 PM
synical1's Avatar
Originally Posted by HondaPartsHero
alright ill try that and let you kno thats for the info save me some time and its good info
Old Jun 7, 2010 | 07:10 PM
shawn_crx's Avatar
Make sure all your grounds have good connections, firing order is correct, and check for spark using the engine to ground your spark.
Hondaciv95VX
Mar 21, 2007 07:53 PM
SulphurDave
Dec 5, 2004 05:39 PM
hybridreams
Nov 24, 2003 09:18 AM
KNO3
Jun 9, 2003 04:43 PM
BLuDoHcReX
11
Dec 24, 2002 05:42 PM
