B16 head on GSR
Old Sep 13, 2002 | 08:06 AM
Kataku2K3's Avatar
Default B16 head on GSR
Hey I don't know why i never really thought of this before, but i was just wondering cuz i'm goin to be reassembling my friends GSR with his OLD B16 head since his B16 block got fucked up when the thrust washer fell out. If he is to go with a Cometic head gasket that is around 0.015-0.020" the compression should remain around what a stock GSR is (10:0-10:1)... But should I just use a B16 head gasket since the cumbustion chamber is round unlike the GSR? Just wondering which one i should use. And for the head bolts can i just use the stock B16's or do i need GSR's. The only reason I'm wondering is cuz i've built LSVTECs and stuff like that before but you always use the gasket for the block.... Thanks in advance...
[Modified by JDMspecEG6, 9:46 AM 9/13/2002]
Old Sep 13, 2002 | 07:41 PM
b19coupe's Avatar
Default Re: B16 head on GSR (JDMspecEG6)
A B16 head will drop compression about 0.4 from a GSR head. The head gaskets for a GSR,Type-R, B16 are all the same.
Old Sep 13, 2002 | 08:18 PM
sgT's Avatar
sgT
stock gasket is around .030" thick. .015-020 will raise the cr a bit.
Old Sep 14, 2002 | 11:30 PM
Kataku2K3's Avatar
Default Re: B16 head on GSR (sgT)
Cool Thank!! Yea we are just tryin to keep the C/R around the same as a stock GSR but with a B16 head.
rauber15
Sep 11, 2017 11:46 AM
Sean DM
Oct 7, 2007 05:55 PM
my4drGSR909
Jan 15, 2007 11:54 PM
mymeatb18"
Jul 8, 2006 11:11 AM
RICE POLICE SIP
10
Mar 29, 2003 09:20 PM
