WANT TO PAINT JDM RISING SUN ON VALVE COVER
Old Jun 6, 2010 | 09:38 AM
EKMIKEY27's Avatar
Default WANT TO PAINT JDM RISING SUN ON VALVE COVER
WHERE CAN I FIND A DIY LIKE STEP BY STEP HOW TO DO IT THANXX
Old Jun 6, 2010 | 09:51 AM
green97coupe's Avatar
Default Re: WANT TO PAINT JDM RISING SUN ON VALVE COVER
Research it man!
Old Jun 6, 2010 | 11:20 AM
PSU's Avatar
PSU
formerly DxHatchback
Caps lock much?
Old Jun 6, 2010 | 11:22 AM
98civdx's Avatar
Master Detailer
Originally Posted by green97coupe
Research it man!
Originally Posted by DxHatchback
Caps lock much?
Old Jun 6, 2010 | 11:29 AM
Corksil's Avatar
GO FIGURE IT OUT DUDE.
I would decide on the base-coat-background-color, and spray that out over a nice clean surface and a coat or two of primer.
Once it looks nice, mask out w/e it is you want to put on there, and spray it with a coat or two of a contrasting color. Remove masking, admire.
heat paint probably.
how hard can you make this?
Old Jun 6, 2010 | 11:35 AM
EKMIKEY27's Avatar
not hard at all ! i jus want to knoe how far do i seperate the stripes and i already polished the cover i want it to look glossy and yeah i cap alot not the point tho
Old Jun 6, 2010 | 11:49 AM
NOFX's Avatar
H-T White Ops
Find a photo you like. Base your design off that.
You can find photos on Google Image Search.
Old Jun 6, 2010 | 12:41 PM
rxbahamut's Avatar
You can prep it about the same way as a paint job I am pretty sure I could be wrong. But from there just make a template and air brush it, or buy a a cut online and air brush it. Then just clear it, I don't know if regular clear will hold up to the heat I have never painted a valve cover, but I bet they make some arousal can clear for high heat. I hope this helps.
mannydhanju
Jan 22, 2009 08:36 AM
huviduc
Oct 3, 2006 04:07 PM
94IntegraLs04
Sep 14, 2004 09:28 PM
hi mom
Mar 8, 2003 01:05 PM
RedDawg
Sep 10, 2001 09:30 AM
