What are the Stock Springrates for the 1997-1998 and 2000-2001 ITR?
Old Sep 13, 2002 | 07:53 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default What are the Stock Springrates for the 1997-1998 and 2000-2001 ITR?
Pretty self-explanatory
And while I'm at it, what do you think are the max rates that the stock ITR struts can handle?
Old Sep 13, 2002 | 08:17 AM
Reid's Avatar
Global Moderator
Default Re: What are the Stock Springrates for the 1997-1998 and 2000-2001 ITR? (B18C5-EH2)
Front springs are linear rate, 4.4 kg/mm (245.872 lb/in), and rear springs are progressive rate, 2.5-4.4 kg/mm (139.7-245.872 lb/in).
FWIW the Spoon progressive rate springs which are designed for stock ITR shocks have rates of:
front 6.5 kg/mm (363.22 lb/in)
rear 5.5 kg/mm (307.34 lb/in)
Old Sep 13, 2002 | 08:20 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: What are the Stock Springrates for the 1997-1998 and 2000-2001 ITR? (Reid)
Thank you.
There are some H&R race springs listed on the King Motorsports site - does anyone happen to know the rates of those?
I have a friend with an ITR and he wants the H&R race, but he would also like to know if the O.E struts will be okay or not.
Thanks again!
Old Sep 14, 2002 | 05:21 AM
len's Avatar
len
Hey Tom, would be best if we just called King and asked. Thanks man.
Old Sep 14, 2002 | 05:24 AM
uNF$@#!'s Avatar
Are you sure about that? I thought the progressive rates were of the front springs
I just doubled checked. You have the rates backwards. front is 160-240, rear is 240.
As a comparison to spoom springs i usually throw in that H&R sports
have a comparative spring rate: 360 in front, 320 in rear.
and i'm sure with any spoom/aftermarket spring,
the "max" rate the spring can handle is probably around 350 or so.
really i think the shocks can handle even more if you want to sacrifice shock life by more Shocks for me are considered a wear item
[Modified by Soup ****, 9:55 AM 9/14/2002]
Old Sep 14, 2002 | 10:14 AM
Reid's Avatar
Global Moderator
Default Re: What are the Stock Springrates for the 1997-1998 and 2000-2001 ITR? (Soup ****)
I just doubled checked. You have the rates backwards. front is 160-240, rear is 240.p
I stand by my original statements.
Old Sep 14, 2002 | 10:17 AM
ZygSpeed's Avatar
I've got to go with Reid on this one, the rears are softer as well as progressive.
Old Sep 14, 2002 | 10:19 AM
ASR's Avatar
ASR
New User
I read that they were 225 lbs front, 180 rear. Mine now are 500lb front 600lb rear, the speedvision integra is 800lb front 1200lb rear. I have a harsh ride but no body roll in the corners with a very predictable amount of oversteer that allows me to basically rotate the car slightly if I want to point it where I need it to go.
Old Sep 14, 2002 | 10:41 AM
Reid's Avatar
Global Moderator
Default Re: What are the Stock Springrates for the 1997-1998 and 2000-2001 ITR? (ASR)
Exact rates are posted above. Why did you go with such soft rates?
You sound like a car salesman.
R.S.
Nov 6, 2003 06:09 AM
R.S.
Nov 6, 2003 06:08 AM
HapiHonda
May 31, 2003 08:34 PM
nugget8000
Jul 28, 2001 05:31 AM
itr501
Jul 10, 2001 04:14 PM
