ITR springs
ITR springs
i posted this in the ITR forum but maybe i will get more responces here
I have all 4 eibach pro kit springs for 94-01 integras and i have ITR rear springs.
the spring rates of the eibach prokit springs are 5.9 kg/mm (331 lb/in) in the front and lower about 33mm (1.3") and for the rear 2.3 to 3.5 kg/mm (126 to 194 lb/in) and lower 33mm (1.3").
But the stock ITR rear springs have a spring rate of 2.5 to 4.4 kg/mm (140 to 246 lb/in) and lower about 13mm (0.51").
If i use the front eibach prokit up front and put the neuspeed koni yellows on a lower perch (one that will make the car lower about 10mm more then what the eibach prokits will lower, so total of about 43mm drop up front and a 5.9 kg/mm springs rate.)
Now for the rear could i use the stock itr springs and put the koni yellows (itr spec) to it's lowest perch, so the total drop in the rear would be about 33mm and the spring rate would be 2.5 to 4.4 kg/mm.
would this be all good?
i would like to do this because i got the itr springs free wit my itr rear lca's and i want the higher spring rate.
-DC2-
Suspension & Brakes
09-07-2007 05:10 PM
B18C5-EH2
09-14-2002 10:41 AM
