12:8 compression how much timing do it i need
at wot to redline you should see around 23-25 degrees of timing..
i'm running 13.0CR low cam i can paste my low / high cam timing from ectune if you'd like.
your WOT timing is much easier to determine. Your daily driving acceleration tables (especially at low loads) are the biggest problem when running high compression and pump gas. Your engine will react differently to every other high compression engine all dependent on the breathing mods you have and the quality of the premium fuel you are using.
my advice is to tow your car to your tuner and have him do it.
________
Avandia Class Action
________
on that note, my WOT timing saw 33* with stock ignition corrections disabled above 550mbar on a little over 12:1 compression.
________
Marijuana sativa
turbodsmpower
Apr 12, 2003 05:55 PM
