A/C works sometimes
Old Jun 4, 2010 | 11:17 PM
4dek's Avatar
Default A/C works sometimes
help me guys its almost summer..my a/c works sometimes. i can hear the clutch engage and sometimes not, but when i push on the climate control panel (not sure what its called, but it is where all the a/c controls and switches are) i can hear the a/c clutch click and a/c starts working and as soon as i let go the a/c clutch disengages again. i know it is a electrical problem but what is causing this? thanks
Old Jun 4, 2010 | 11:22 PM
D16SiHatch's Avatar
Default Re: A/C works sometimes
if the a/c switch isn't staying lit up then it's likely just the switch that's bad. replace it if you can, otherwise replace the whole heater control panel. i had to replace mine because although the a/c button lit up it wasn't telling the condenser fan or compressor to kick on.
Old Jun 6, 2010 | 12:59 AM
4dek's Avatar
a/c button is lit. i just have to push against the panel to have the a/c kick in but when i let go the compressor disengages right away. why why why?
Old Jun 6, 2010 | 04:41 AM
CarGuy75's Avatar
X2. Same problem happened in my old hatch. I had to replace a/c (heater) control panel.
Old Jun 6, 2010 | 05:25 AM
grumblemarc's Avatar
The Grumpiest
Ground wire came loose in the engine bay.
Bubezzy
Dec 3, 2017 03:14 PM
Han_Duh_Solo
Nov 23, 2015 06:15 AM
kingK
Oct 30, 2015 12:41 PM
bnewall1
Nov 19, 2013 12:01 AM
efyou
Oct 9, 2007 01:54 PM
