Megan Racing Header
I am thinking about getting a Megan Racing Header. The reason is, I stripped my 02 bung on the flex pipe. I heard that the gaskets suck on these things. Does anyone know what I can replace them with prior to installing it? I am giving the car to my brother in law, so I want this to last for a while. Thanks in advance.
the gaskets that came with my megan header and downpipe were fine. on the flip side, the gaskets that i got with my cheap temporary ebay header sucked, they kept blowing out. if you need new gaskets just get some high temp gasket maker. it works fine, and is what i used when the gaskets on my ebay header failed. no problems since!
By the sound of things, he isnt trying to go fast, and instead just needs a new header. The Megan header is a cheap replacement for a stock header as long as you arent looking for more power.
MEGAN is not Garbage.. It's just not a Tri-Y It's a dirt cheap OEM replacement.
If you're going to buy something, save for a Tri-Y
My economical advise, Weld the O2 sensor to the bung. It will work. You'll need to replace the sensor though, when you replace the header. Good Idea anyway-
