NEW A/C no cold air
i have just put a new compressor and condenser new belt and went to get it fulled at the honda dealer.they will not touch the car because of the after market parts i have all they did was charge it. the ac is blowing HOT air i could use some BIG help please im in texas and its hot as hell
I would take it to another shop or troubleshoot it yourself. You can Rent Vacuum Pumps and Gauge Manifolds from some Auto Parts stores and then do it all yourself.
If you decide to look into DIY. Here's an excellent guide for you to go by that explains the reason for pulling a Deep Vacuum and steps to charge, also explains how your A/C system works if you don't already know to expand your knowledge.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-how-charge-your-c-air-conditioner-conditioning-system-home-1665946/
What year car BTW?
What year car BTW?
Have a good mechanic check that the dryer canister or something else isn't resting on the compressor lines. Something that simple could be causing your problem. Trust me, that's what happened to me with my Integra. Also, ask whoever did your work, if they flushed out all the hoses and put oil in the compressor because if they didn't, your compressor is going to mess up.
tallguy21
Feb 15, 2011 07:08 PM
neEven
Jul 23, 2005 12:49 PM
