95 Accord F22b auto trans issues....HELP!!!!!
ALrighty guys long story short I have this 95 Accord with an Auto trans f22b.... well i did a complete swap with all the stock components bc my vehicle had 200000 miles.... well about 2 weeks after the swap i noticed that when the vehicle had been driven for around 20 mins the trans would no longer downshift when u mashed on throttle... i could manually select the gear and it would do fine.. in addition the vehicle when starting from a dead stop would shift at 3000 rpms for ever gear no matter what..... but when u just put the car in neutral while driving and shut the power off and start it back up the issue would go away for another 20 mins or so....
I have checked the trans codes and i only get a code when the vehicle is on and has just stated acting up....the code i pull is code 3.... i hear from sum ppl that code3 is MAP sensor issue... others say its the TPS..... any help on this matter would make my life much easier as I and my friends are all stumped...
The shift points are controlled by shift solenoids A and B activated by the PCM. Since the problem goes away when you restart the car, I would think it is a command issue from the PCM and not an internal transmission problem or throttle valve cable adjustment. Since you have a code 3 (Map Sensor) then I would start there. Look for a vacuum leak from a cracked or disconnected hose.
accordian88
Mar 5, 2013 06:08 PM
beatnu50
Jun 5, 2008 07:30 PM
