d16y8 engine in 92 hatchback
Old Jun 3, 2010 | 02:57 PM
97dssi's Avatar
Default d16y8 engine in 92 hatchback
i was wondering do i have to hook up to crank sensor? engine wont idle.. it will die after about 5 sec
i changed TPS sensor, TB, and idle air control valve
Old Jun 3, 2010 | 02:58 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: d16y8 engine in 92 hatchback
No. Any check engine lights?
Old Jun 3, 2010 | 03:03 PM
jdmh22eg2's Avatar
if u are using a p28 then no it does not look for the crank trigger, knock sensor
Old Jun 3, 2010 | 03:13 PM
97dssi's Avatar
yes CEL is on... i got 3, 21, and 41
yes i used to have p06 i think but right now i put p28 in there
Old Jun 3, 2010 | 03:39 PM
jdmh22eg2's Avatar
ok code 3 is map sensor
code 21 is vtec solenoid
code 41 is o2 heater circuit
might all be bad sensors have to fig those things out before u go anywere else sounds like ur main prob main be the Map sensor( oh **** try switching the map and tps clips )
Old Jun 3, 2010 | 03:46 PM
97dssi's Avatar
i tried switching the map and tps clips and it doing same thing..
map sensor is behind manifold am i right?
how do i check vtec solenoid?
Old Jun 3, 2010 | 03:50 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
No. The map sensor is the one on the top of the throttle body. Is this an si hatch? Is the wiring for your vtec correct?
Old Jun 3, 2010 | 03:52 PM
97dssi's Avatar
yea i already changed different map sensor... no my hatch is dx..
Old Jun 3, 2010 | 03:53 PM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
So how is your vtec wired? Your stock harness doesn't have plugs for the vtec solenoid.
Old Jun 3, 2010 | 03:57 PM
97dssi's Avatar
well i got 92-95 si harness for it and its hooked up but im not sure if it hook to my stock cabin harness
Old Jun 3, 2010 | 05:06 PM
87 SiviK Si's Avatar
92 hatched came prewired for VTEC, so, it a matter of wiring from the solenoid to the cannon plug. Check the TPS and there is one more sensor that you need to swap over from the y8. I cant remember what its called but o the y8 its on the intake tube, and on the b7/z6 it was on the intake mani..
Old Jun 3, 2010 | 05:26 PM
97dssi's Avatar
well my cabin harness came from 93 hatch dx because the old cabin harness used to be in 92 hatch few wires melted and messed up so i swap it from 93 hatch. so i should get different manifold or just change sensors?
Old Jun 3, 2010 | 05:33 PM
I just looked it up. Its the IAT sensor. on EG's its on the mani, you have 2 options. drill a hole and JB weld the IAT to the y8 manifold (the way it says to do it on a swap guide I have) or just extend the wiring to the intake tube and install it there.
Old Jun 3, 2010 | 06:42 PM
97dssi's Avatar
Really? i dont get CEL on that ?
Old Jun 4, 2010 | 02:43 AM
PhantoM.DA's Avatar
GDD GRAMMAR POLICE
Which intake manifold are you using? I did the same swap but in an 95 ex coupe, i used the z6 intake manifold.
Old Jun 4, 2010 | 09:49 AM
97dssi's Avatar
probably d16y8 manifold... ok i think i might go to junkyard to find a d16z6 manifold. auto or manual doesn't matter or ?
Old Jun 5, 2010 | 01:36 AM
97dssi's Avatar
ttt
Old Jun 5, 2010 | 11:50 AM
97dssi's Avatar
TTT
chucky86
Oct 13, 2011 02:46 PM
black sohc civic
Oct 30, 2005 07:02 PM
chrysler kid
Sep 28, 2004 07:24 PM
Charlie Moua
Jun 30, 2004 04:47 PM
