differential fluid
Old Jun 3, 2010 | 10:19 AM
SeanK325's Avatar
Default differential fluid
honda oem i'm sure. but how often? how much? is there a DIY?
Old Jun 3, 2010 | 10:20 AM
mayfly's Avatar
Default Re: differential fluid
every 30,000 miles. use oem genuine honda manual transmission fluid.(im assuming your car is a 5 speed)
mayfly's Avatar
i believe it is $7.40 a quart
Old Jun 3, 2010 | 10:21 AM
SeanK325's Avatar
yeah it is a 5 speed. how much do i buy?
Old Jun 3, 2010 | 10:25 AM
mayfly's Avatar
2 quarts.
Old Jun 3, 2010 | 10:26 AM
mayfly's Avatar
drain all your fluid. then fill it up. use all 2 quarts
Old Jun 3, 2010 | 10:30 AM
SeanK325's Avatar
thanks man. i've never done it before so i'm not sure how to go about it. any tips?
Old Jun 3, 2010 | 10:42 AM
DCRB's Avatar
5spd? i pull the vss out, then take off the fill cap, then using a funnel and a tube i fill the trans up through the speed sensor till it starts to drip out of the fill hole. much easyer imo. you can also go through the reverse sensor
ManInBlack
Honda Civic (2006 - 2015)
Jul 15, 2013 03:04 PM
ajpturbopittsburgh
Honda Civic (2001 - 2005)
Dec 27, 2008 08:47 PM
Unseen Racer
Dec 21, 2008 05:21 PM
tom48
Jul 14, 2008 08:30 PM
luv2boost
Aug 8, 2007 08:10 PM
