D16y7 build. 75.50 pistons wat headgasket?
I am building a y7 block with 9:1 cr pistons 75.50mm. Can u use a oem head gasket? I have a new one sitting in my garage. Or do I need to get a 75.50mm headgasket.
^^Lol.
That question does got me thinking a bit too. I'll let the expert chime in as I'm not sure about this. You might need to get a custom head gasket; since, the bore are bigger than standard OEM HG.
Im no expect on the sohc motors but I can say for sho...
that you can not use the stock HG...The pistons would be slapping the crap out of of the metal rings on the HG itself...
You need one A specific to your bore...
maybe check this one out? just a heads up tho if you use the cometic make sure your deck surface is done correctly for that hg or it will ooze and never really seat...
http://cgi.ebay.com/ebaymotors/Comet...Q5fAccessories
best reply so far. if that doesnt work then your only other option is to get one specific to your bore size (recommended). you dont want a head gasket hanging out into the cylinder for any reason.
thread jacking this for a second... do you need to bore/hone out the .5mm in the cylinder for the new over-sized pistons?
if youre going with an oversize piston then having the cylinders bored is pretty much a given unless you were running a ridiculous tolerance before and enjoyed a little piston slap. when you bore.... you hone.
Then somoene posts about how the headgasket is made to "Exact specs" and gets credit for the "best post ever"... I love this place. Where else can you come and see so much mislead information splattered around and then a group of equally mislead individuals telling him how great his information is?
I just mic'd a stock D16y8 headgasket I have in the garage. Its 75.55mm. Hows that for "Exact specifications"? Will your 75.5mm pistons work with a stock headgasket now?
well i took the oem hg to the machine shop since my block is there and he is gonna mic the hg to make sure it will work. from the look of it he said i should be fine but he will double check. ill keep yall posted.
SupaFly_Honda
Jun 25, 2009 09:16 AM
