knock sensor help?
Old Jun 3, 2010 | 12:03 AM
illios's Avatar
Default knock sensor help?
soo i was connecting my harness to my b16a2 block and i connected the oil pressure sensor, then when i wanted to connect the other 2 plugs in the set with the oil pressure sensor, i couldnt find a place to plug these plugs? i believe one of them is the knock sensor... i googled it and the knock sensor should be in the back middle of the block... but i dont have any sensor connect on the back middle of the block, i see a place where the hole where the knock sensor "might" have been.
so my question is... since im missing the connector to my knock sensor, can screw the sensor off my d-series motor and put it on the b-series? are they interchangable?
also can someone tell me what exactly a knock sensor is? do i even need it?
and if anyone knows.. what is the other sensor on that set of sensors?
Old Jun 3, 2010 | 12:14 AM
3starz's Avatar
Default Re: knock sensor help?
my 96 Civic dx engine harness knock sensor connector and other fits onto the sensors on the GSR swap I did no problems. Beside IAB, I have to cut the connector from the GSR harness and slice it to the Civic harness. I think you could use the d-series knock sensor, I'm not to sure. You can try. Good Luck!!
Old Jun 3, 2010 | 03:50 AM
illios's Avatar
lol well actually im not talking about the connectors on my harness, im talkin about the connector on the block itself it looks like this:
i have the sensor on the d-series i wonder if i can put it on the b-series with no problems? anyone know?
Old Jun 3, 2010 | 07:18 AM
MonkeyMagic's Avatar
yup.
unscrew and put in the new motor
93SiVTEC16794
Nov 22, 2013 01:36 AM
92'si
Feb 8, 2010 06:27 PM
hoezee
Oct 6, 2008 10:40 AM
bb4socal
Feb 25, 2006 03:46 PM
shadykit
18
Mar 14, 2005 12:51 PM
