power windows
So I don't know what I did, but the other day I took off my drivers side door panel and got the window to go up and down right with no issues. When I got everything put back together the drivers window worked but none of the other windows work at all. I made sure that I plugged everything back in, I checked all the fuses that I could find. Any suggestions on what is wrong?
pull the switch panel back off and make sure you hooked all the leads back up. on my 94 accord, there is a small (dark red i believe) connector that I have forgotten about before and i think it caused the same issue. if you have a friend with the same master switch, hook his up to yours. you may have accidentally damaged your switches. if you have a manual with a diagram for the switch assembly, you can test continuity to see if it's bad.
I agree, just did this on a 93 accord, the main switch has two plugs, if you don't plug both in the drivers side will work but the none of the others will work either from their switches or the main switch
chris4x4
13
May 8, 2011 10:39 AM
