help set up Boost by Gear s300
Old Jun 2, 2010 | 05:00 PM
kmaz93da's Avatar
Default help set up Boost by Gear s300
what method should i pick? why?
-fixed duty cycle
-gear base duty cycle
-gear base target boost
first time with s300 and dont hav clue how setup boost by gear,im running gsr turbo 430hp, on 225dr for the street, like low boost to have 10psi in 1st and part 2nd, than up to 16psi to end of 3rd and 18psi in 4th..
can anyone give me good guidline or show me their calib.graph that i can go off of? thanks
Old Jun 3, 2010 | 06:06 AM
mtber's Avatar
Default Re: help set up Boost by Gear s300
Gear based target boost.
You must figure out what duty cycle does what using fixed duty cycle first, then you can setup your reference tables.
Old Jun 3, 2010 | 09:27 AM
0100101's Avatar
Vega!! I havent seen you around in forever!! Kmazda- def listen to mtber, he is one of the best. Check out his web site phearable.net
b16bri
Jan 26, 2012 01:51 PM
kmaz93da
Jun 2, 2010 06:24 PM
eghatchproject
Feb 21, 2004 04:57 PM
djnikko
Aug 14, 2003 03:55 AM
ludelvr
Jun 24, 2002 12:31 AM
