Integ dashes in EG
Old Sep 12, 2002 | 11:31 PM
1EK1EG's Avatar
Default Integ dashes in EG
I was just wondering what integ dashes will fit into a EG with the least modification? Thanks for your time and sorry if youve heard this one before.
Old Sep 12, 2002 | 11:45 PM
Evil_Wizard's Avatar
Default Re: Integ dashes in EG (GreenCivicEg)
Do you want to keep your AC?????
Old Sep 13, 2002 | 05:03 AM
TurboBumblBee's Avatar
any 94-01 integra dash will fit into a civic w/ some modifications but it requires lots of rewiring.. and it doesnt look perfect at all cause you have to cut the stock door trim to make it fit.. you would need the dash, cluster, a/c and heater box, center console, takes a lot to make it work, i wanted to do it once but not on my list right now..
Old Sep 13, 2002 | 05:23 AM
zc911's Avatar
Default Re: Integ dashes in EG (95CivicEX)
actaully it goes in pretty clean . if you wnat pics i'll get some
you can also just cut the civic heater stuff that gets in the way. If you drive your car in winter probably not a good idea .
Old Sep 13, 2002 | 08:48 AM
Default Re: Integ dashes in EG (zc911)
yes infact i would LOVE to see some pics of an integra dash in a civic that looks clean and just a good as factory and then for you to tell me how it was done.. ive done this for a friend in his civic and the only way you can make it look good is to possibly heat up the door panels so you can form them around the teg dash..
please show me these pics you have a of clean looking factory teg dash in a civic.. thanks
Old Sep 13, 2002 | 09:00 AM
k.'s Avatar
k.
New User
I've seen it done! Its clean as hell!!
~k.
Old Sep 13, 2002 | 09:30 AM
jdmitr98's Avatar
Default Re: Integ dashes in EG (k.)
~k.
Old Sep 13, 2002 | 09:33 AM
oldB18EF's Avatar
Default Re: Integ dashes in EG (jdmitr98)
wheres the thread of that dood who took all his stuff from his wrecked ITR and swapped it into an EG- that was the cleanest crap ive ever seen
Old Sep 13, 2002 | 10:52 AM
zc911's Avatar
no prob i'll take some tonight when i get home, check back around 7-8pm tonight(eastern time)
And ya thas pretty much what was done to get the dash in, i dunno looks a ok to me
Old Sep 13, 2002 | 11:14 AM
SPOON_BeIgHtEeNsEe's Avatar
this is my cusin car... its looks ... i also have one in my eg too... no pics of mine but heres his (b16_ef)
Old Sep 13, 2002 | 11:21 AM
dose's Avatar
ive seen a prson cut the door panels from a civic and teg and pice em together to fit GOOD
Old Sep 13, 2002 | 11:23 AM
1EK1EG's Avatar
Default Re: Integ dashes in EG (SPOON_BeIgHtEeNsEe)
Thanks for the pics.Im still deciding on whether to do it or not.If i do, it wont be for some time now because i would rather get my motor in Keeping the AC is not a big concern because where i live,it doesnt get to hot,but i would need to keep my heater because its a little on the colder side.Tell your cousin, the dash looks nice.Hope to see some more pics.
Old Sep 13, 2002 | 11:41 AM
TruePlayaz114's Avatar
will the teg dash fit in a 92 4 dr
Old Sep 13, 2002 | 12:14 PM
bikeboy80's Avatar
Default Re: Integ dashes in EG (TruePlayaz114)
stripped
teg dash
try this if thoes dont work
http://www.imagestation.com/album/pi...?id=4291411383
i had a integra that i totaled and bought back, so it was relativly easy to go in, i used the teg harnesses so i didnot have to rewre anything, i still have to figure out what i am going to do for the door panels though
[Modified by bikeboy80, 1:16 PM 9/13/2002]
Old Sep 13, 2002 | 05:26 PM
1EK1EG's Avatar
Default Re: Integ dashes in EG (bikeboy80)
Wow,man that looks like a pain in the a*s.Well for me it would be because i really wouldnt know what to do.Looking good
Old Sep 13, 2002 | 10:24 PM
where is the passenger airbag? how much of the door panels were cut?? i know it can look good but its only worth if if your going for show or something honestly.. my long term goals for my coupe are integra gsr motor, integra dash, and an integra front end conversion... this car will be for show only as you can tell.. but it will be worth it when im done..
Old Sep 13, 2002 | 11:09 PM
racecarpete's Avatar
it is up to you to decide whether it is worth it. if you look at the first pic, you can see where the door panels are cut it just doesn't look that good. Now if you were to be skilled, mold them together. someone did it here and it looks fatory. just strip then cut the civic panel and teg panel where they are pretty much the same size somewhere in the rear and then have them wrapped. i would do it if i had an eg.
ozziehonda
Feb 8, 2008 04:10 PM
turbojohnny
Jun 26, 2007 10:02 AM
JDMEK328
Jul 28, 2006 09:21 PM
yor2slo
16
Oct 21, 2003 07:54 AM
SHFTAT8
Nov 13, 2002 01:59 PM
