Integra dash in EG (how well does it REALLY fit)?
Did a search and found a couple pics and info, but not exactly what I was looking for. Wanna know from people who have actually done this, how well does it truly fit in a EG hatch? Is there any gaps or edges that would normally not be there with the stock dash? Detailed pics would be awesome. Thanks in advance for any of your help.
Re: Integra dash in EG (how well does it REALLY fit)? (SHFTAT8)
i believe that the steering column and door panels (where they meet up with the dash) are the only major problems
Former Moderator
Re: Integra dash in EG (SpoonFedHatch)
well actually i saw the finished product and the final install of panels....but they pretty much told me all that had to be done
Liam821 did it...I bookmarked it, hope he doesnt mind if I use his link...here ya go
https://honda-tech.com/zerothread?id=285567
Re: Integra dash in EG (B18C5-EH2)
mine fits fairly well, it's not perfect
i removed lots of material from under the gauge cluster to make it fit around the column, and had to make up new brackets for the ends to attach to. in the end the driver side of the dash is about 1/4 inch higher then the passenger side (good enough for me) also i remember a little plastic had to be shaved off the back of the lower driver pannel to fit agasinst the metal knee bracket, also the little coin tray had to be cut (not like i ever used it anyways)also there are little 1/8 inch gaps on either end of the dash, as for the door pannels they will not fit, i am still working on mine right now to make them fit, i pulled off the vynal and cut some of the plastic to fit around the dash, my next step is to fill in the holes with some fiberglass, and then rewrap the pannels with new vynal
in the end, im glad i did it (i like the teg dash better) i'm not going for a show quality finish anyways, everyone who sees it in person coments on how well it seems to fit. also i had all the parts from my wrecked teg so parts wern't an issue, same thing with the wiring of the cluster, i used a teg harness so again that was not a problem
there are a few pics on my site below, but i will try and go out tomorow and take some better pics
Sprayin_civic
05-05-2005 09:36 AM
SPOON_BeIgHtEeNsEe
11
10-23-2001 06:43 PM
