Anyone located near Nassau Long Island?
Old Jun 1, 2010 | 02:53 PM
94h22acord's Avatar
Default Anyone located near Nassau Long Island?
i have a computer issue and need to see if someone could try my obd1 vtec hondata s300 ECU to see if it works.
Old Jun 1, 2010 | 05:08 PM
94h22acord's Avatar
Default Re: Anyone located near Nassau Long Island?
bump...need help please
Old Jun 2, 2010 | 04:20 AM
richi86's Avatar
BUMP ... what is the issue u are having right now ?
Old Jun 2, 2010 | 10:16 AM
94h22acord's Avatar
car worked perfect after rebuild for four months then one day when driving the check engine light came on and the car started fluttering and it wont let me hit the accelerator due to the hondata saftey. i fought through it to keep it from stalling then the problem just vanished.
i got it to work started it and it drove perfect all the way home. tried to take it to work the next day wouldnt start. came home from work tried to start it and it was perfect again.
changed cap rotor coil and igniter in the dzzy thinkin that could def b the issue. no fix
swapped out main relays. no fix
tore the dash out again to check for a short in the wires i extended during the build. everything is perfect.
im thinkin it has to be the s300 or ecu because it is an intermittent problem, if it was a short in wiring it would b a constant problem, and everything else checked out ok
Old Jun 3, 2010 | 07:29 AM
richi86's Avatar
yes that sounds like an ecu to me too.. is there anyone u know with one u can swap out for a while just to test it out and see ?
Old Jun 3, 2010 | 10:09 AM
94h22acord's Avatar
thats why i started this post hahaha...i want someone to come over and try my ecu with the s300 to see if their map works on their car with my ecu...right now my ecu is at a shop and i need to get it to bring it to chris millers shop which is only 20 minutes from me (world record holder outlaw FWD civic). i was just seeing if somone lived close by that could help me out by letting me try my ecu on their car.
Old Jun 5, 2010 | 08:03 AM
94h22acord's Avatar
ttt
Old Jun 7, 2010 | 03:01 PM
94h22acord's Avatar
ttt
em2crusin
K Series
Jun 9, 2013 11:40 PM
hyboost
Engine Management and Tuning
Jan 14, 2011 07:13 PM
TokuiAutowerks
Dec 13, 2004 07:29 PM
94gsr_vtc
Oct 22, 2004 12:58 PM
hahahahhah
18
Feb 13, 2003 10:59 PM
