balanced and blueprinted??
Old Sep 12, 2002 | 09:37 PM
myballs's Avatar
Default balanced and blueprinted??
anyone know any good places for a good price to get your cranck balanced and blueprinted ..... thanks
Old Sep 13, 2002 | 12:55 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: balanced and blueprinted?? (Sohroub)
i heard about this shoppe in japan mainland, they are the best....
with questions like that, you'll get no answers...
where are you from? what motor, etc...
stan
Old Sep 13, 2002 | 05:07 AM
boomslang's Avatar
Any decent machine shop can do it. Have your crank, flywheel & bolts, crank pulley & bolt, timing belt sprocket and plates all balanced at the same time. They just bolt it all together and balance it as an assembly.
Have your rods and pistons done as well.
Old Sep 13, 2002 | 07:12 AM
IN VTEC's Avatar
Ask your local dealerships (and especially the Honda and Acura dealers) for which machine shop they recommend or outsource their engine rebuilds to.
Chances are that you might not find a shop that has done Honda rebuilds b/c of Honda's policy of replacing instead of rebuilding. Too much liability and time in rebuilds.
But, I'm sure somebody in the Service or Parts dept's can tell you who they use. Then scope out the shop, and talk with them about your application and what they need from you to get the job done. Ask about warranty on any work that they do, and get a price quote. Might wanna bring a pen and paper b/c I never got a chance to write down all the quotes for each different item.
Old Sep 15, 2002 | 06:12 PM
myballs's Avatar
yeah its for a h22a engine... what price range would i be lookin at roughly?
Old Sep 15, 2002 | 07:37 PM
IN VTEC's Avatar
I spend $200 on the following:
.Removing/installing valve guides
.Recutting intake and exhaust valve seats on the head and back cutting the valves
.Checking head and block deck for straightness
.Removing/installing pistons
.Cross-checking weights b/w the JDM P73-00 pistons vs. my stock P72-A0 pistons
.Hot tanking head and block
.Removing/installing main oil seals on the oil pump and flywheel cover
I believe an internal balancing would have cost me another $80.
Old Sep 18, 2002 | 08:11 PM
myballs's Avatar
Default Re: balanced and blueprinted?? (IN VTEC)
where you get it done at?
Old Sep 18, 2002 | 08:13 PM
IN VTEC's Avatar
Local place in town called Davis Automotive.
raverx3m
Oct 19, 2014 10:31 AM
snookums
24
Sep 27, 2013 06:47 AM
Hirousuke
Mar 20, 2007 11:35 AM
STI champstar
Acura TL, RL & ZDX
Sep 3, 2006 05:51 AM
Bnjmn
May 22, 2003 01:53 PM
