People with cr vtec questions?
Old Sep 12, 2002 | 09:02 PM
drvfast's Avatar
Default People with cr vtec questions?
How long has your motor lasted so far? How much did it cost to build?
Old Sep 12, 2002 | 09:04 PM
TREVER's Avatar
Default Re: People with cr vtec questions? (drvfast)
8k plus so far. I built it myself, so no cost.
Old Sep 12, 2002 | 09:14 PM
drvfast's Avatar
Default Re: People with cr vtec questions? (TREVER)
thanks i'm planing on building it with a freind just wantd to see how much u guys have put into u setup so far and how is it running? i met a guy and he said his is running terrible and is trying to get rid of it. but i willing to do this setup.
Old Sep 13, 2002 | 05:01 AM
sparq's Avatar
It all depends on how you want to do it. If your going to run higher compression pistons you NEED to get the CRV re-sleeved. Same with going FI - if your going anything over 8psi just get the thing resleeved so you dont even have to THINK about it being the wink link in your setup.
So it depends, just want a STOCK CRVTEC? Going for a higher ouput N/A setup? Forced Induction? Cost buildup will vary based on many things. Most setups that I see that people are "building it right" spend about $3500-$5000 for the whole shibang.
Old Sep 13, 2002 | 05:49 AM
X2BOARD's Avatar
Default Re: People with cr vtec questions? (sparq)
vWhy are you so set on sleeving for higher compression pistons on the CRVT ? I have an LSVT and know on those you don't NEED to sleeve for higher compression... OR for FI for that matter and I've already run it turbo'd to 8K with no problems.
Anyone know the R/S ratio on a B20 block ?
I don't think you would need to sleeve for low boost or a mildly high CR, doesn't make sense.
Anyone care to enlighten me on this ?
X2
Old Sep 13, 2002 | 06:12 AM
drvfast's Avatar
yes i'm going to run higher compression pistions and i will resleeve the block and bore it to 84.5mm. i think i will be running 11:1 or mabe a little higher i am planing on going n/a. well thanks for the response
Old Sep 13, 2002 | 06:25 AM
sparq's Avatar
Default Re: People with cr vtec questions? (X2BOARD)
Bro, the LS sleeves and CRV sleeves are TOTALLY differant, the LS sleeve design is much better - which is why you dont need it.
Old Sep 13, 2002 | 06:45 AM
X2BOARD's Avatar
Well, that kinda sucks... I thought the block was almost the same as the LS/GSR design...
What's so different/ bad about the B20 block exactly ?
Old Sep 13, 2002 | 07:34 AM
sparq's Avatar
I dunno I didnt design them
It has to do with the sleeving - early B20's (dont know about newer ones) had some kinda flaw I guess. Like I said I dont know the specifics im just running my mouth - like the news is with this "Terrorism" thats going on in Florida right now. LOL
Old Sep 13, 2002 | 07:43 AM
X2BOARD's Avatar
No new news on that yet.... but the damn guys had a Prelude !
Old Sep 13, 2002 | 08:04 AM
TREVER's Avatar
r/s 1.54
I run 11.2 c/r and a 100 shot and I haven't cracked a sleeve.
I do wish my block had some GE sleeves.
B20 blocks have siamese sleeves that are supossed to be stronger, but because they are 3mm thinner they tend to crack.
11.1 is low compression in my book, and will be fine with stock sleeves
Old Sep 13, 2002 | 09:27 AM
Ham'ed Hatch
Guest
Posts: n/a
mine's been running strong for about 11 months now.
sorry, don't know exact mileage.
Old Sep 15, 2002 | 09:06 AM
jg's Avatar
jg
exactly. The b20 block contains 1 big, siamesed sleeve, whereas all the other b-series blocks are 4 individual sleeves. I have a b20 vtec running Endyn high-comp. pistions- you'll want to sleeve if if you're going to run high-comp. pistions. The nice guy I talked to at Golden Eagle said it's VERY common for the b20 sleeve to crack where the two cylinders come together. Here's crappy pic:
Old Sep 15, 2002 | 12:24 PM
2.2's Avatar
2.2
If you are going to resleeve the block anyway, why not get a B18C block? It will bolt up to a VTEC head without having to run external oil lines for VTEC and all that.
Old Sep 15, 2002 | 01:05 PM
ANB Clothing Co's Avatar
Default Re: People with cr vtec questions? (2.2)
thats what im sayin....and a gsr block is cheaper than a b20 nowadays anyway....i used to have a 2.0 liter gsr block and it was really nice...
Old Sep 15, 2002 | 02:18 PM
Kataku2K3's Avatar
Default Re: People with cr vtec questions? (KingKong)
My friends 96 hatch has a CRVTEC, .50 over JE 12.5:1 pistons, stock rods, Portflow GSR head, CTR intake cam, sprockets, Skunk manifold, JDM ITR header, RC 310cc injectors, Type R ECU and VAFC for fuel. His best run with no passenger or rear seat is 12.6@107 on M&H 22x9.5x13s. He's had it for several months now and still running great. It costed roughly $8,000 but it was definately worth it.. I personally still would rather have a GSR block, just sleeve it up to 85mm which bumps ur displacement to 1.98L or 86mm 2.03L. Who cares about the 1.8mm of stroke that a CRV or LS has over the GSR. Either one is tight tho
h22 kid
Nov 15, 2009 01:33 PM
Dave_Dc2
12
Oct 18, 2008 01:45 PM
hellcivic1996
Jan 22, 2007 05:58 PM
bogus_ek
Feb 3, 2004 09:38 AM
TeamTooQuick
May 22, 2002 10:16 AM
