Why does my transmission shift at high RPM?
Ive had my 2000 honda accord ex for like 3 months now.. 91k miles on it currently. When i bought it from a guy he said the kid before him modded it to shift that way. Is that true? I went to Honda and had it diagnosed. They said i need a whole new transmission and there is something wrong with the internal clutch. Any help?
I wouldn't be surprised if the guy lied to you knowing it needed a transmission.
This transmission doesn't have a kick-down cable or anything like that. I think you got took.
look, transmission is computer controlled and it determines the shift points and if honda states you need a new trans, then there really is no need to go further. Honda has an entire procedure to determine if the trans need to be replaced or not. Since a 2000 accord has a stout motor (I4 or V6) replacing the trans with a honda reman one will let you drive the car for many more years after you do the timing belt
Dont over look it could be his springs and detents. However, in order to know what is going on you really need to take it apart. It might be cheaper to rebuild it (only buying the parts you need) then to buy a new tranny.
As far as what the previous owner told you, he definitely lied. You should have had it inspected by a mechanic before you bought it as they would have certainly told you that was a load of s#@t. But as that's in the past, nothing you can change, so lesson learned.
Moving on, was that 3 grand quote from the Honda dealer? Frankly, thats way too much (go figure from a dealership) and there are places who do installs on new/remanufactured auto transmissions for several hundred bucks. Your problem is finding a place in your area that does this, and does it PROPERLY. Let us know what area you are in and maybe someone will know of a shop nearby.
You could do what your friend said and get a junkyard transmission, but are you capable of doing the swap? If so you could definitely save yourself some coin. Don't try this though if you don't have much experience.
You can also try and approach the company itself and see what warranty is still out for your powertrain. If you have the V6 you might be able to get something from them (they approach claims on a case to case basis from what I've gathered). As for the 4 cylinder, I don't think they will be much help. The auto in that is pretty bad, but not nearly as horrible as the one mated to the V6.
Good luck with whatever you decide to do.
Thanks for that Bwill.. I live in the central florida orlando area. Im going to have a mechanic take a look at my tranny this week sometime. I just dont know what im gonna do yet. Thanks for everything
If you are gonna have to replace it anyway, and it still works, why not?
Probably should limit your distance though and maybe not drive it so much. Don't want it crapping out on you at a bad time while you are on the road. Also you want to limit the increased stress on the motor (if its just short drives you are probably fine, its a Honda motor for cryin' out loud) if it's always shifting in the higher rpms over a longer drive with a lot of gear changing. How high are we talking here btw?
Yeah I don't doubt that's a normal price from Honda. Before replacing these things became more commonplace that's the only price range I heard for it. Good thing you can find places that will do it cheaper now AND will usually have some sort of reasonable warranty.
It usually shifts from 1st to 2nd like 4 to 5 rpm then as 2nd to 3rd a little lower rpm but after that it usually shifts fine.
i would not go outside of honda for a rebuild I tried a well known shop (kennedy transmission) and they had to rebuild it 4 times within 11k miles (a 1998 accord v6)
newest honda reman has all updates and should last the life of the car.
just search kennedy transmission in the archives
I know there have been others on this site who have had good luck with some shops but you'd have to search the threads to find them. No doubt that Honda's rebuild will do great, but you might as well swap to a manual and learn to drive stick instead of paying that...
Anyone else with shop experiences?
I did it for just over $300, cause I had a free gearbox and a few other things.
I absolutely could not stand driving my car without the manual. Of course, not everyone feels the same way so... gotta offer other suggestions I guess.
the thing is with my tranny, that it wasn't broke, i just got tired of the auto holdin me back, it is for sale now if anyone wants it
I have had the same issue with my 2001 Honda Civic. It comes and goes and every time the mechanic looks at it it functions properly. Every time I do have an issue with the transmission I have to manually unlock the shifter. Any ideas as to why the problems are erratic and are they related some how?
adnanrajput
Jan 15, 2013 05:32 PM
Elvis1977
Feb 27, 2004 07:28 AM
