cylider wall chipped? is it ok?
i have a 92 teg with a b18a. i noticed that there is a chunk taken out of my cylinder wall on the outside in the water jacket. i need to know what you guys think. there is no crack in the cylinder and it looks like it was a factory defect from new. do you think im ok. im not running any turbo or nothing i juat want a reliable stock b18.
the car ran before but not very good. it had alot of vacumm leaks and hoses with spits on them. it was under the ownership 2 totally incompetant people. the original head had bent intake valves so my buddy who i bought it from changed the head. the head bolts were def tourqed harder than they should have been and he broke off a cam cap oil feed bolt. i have a head from my first da. the trans is missing 3 bolts so far but might be missing more. uuuggghhh this car is going to make me go grey. is there a speacial kind of head gasket for leak prone motors. something that will crush a little better than an oem hg.
is that ok? i thought they have to go on dry. i will ask my buddys at the dealership what they think. and i will post what they say. i have to wait till tuesday to see them
my two buddys from the honda dealer near me said that i should take it to a machine shop and ask them but i dont want to take the block out of the car. im just going to use a fresh oem gaket and hope for the best.
So I put the motor back together with a new headgasket and head bolts. The motor runs perfect! I haven't put any miles on it but it's run for about 30 min total. Just running it to test things like the exhaust and stuff. I haven't noticed any oil around the head gasket or anything but once I get it on the road and drive it for a little bit I will post my results
Could have coated the chipped area with JB weld to reinforce it,
Look like somethin was dropped down on it the way the chip is, possibly the head that was being taken off originally...
he bro i jus bought a 1999 gsr with a new head and its overheats i put new thermostat and flushed it problems got worst with overheating. and than my radiator temp switch was un plugged and has a paper clip on it to bypass it. and finally i took to mechanic and he said its probly head gasket and when they took head off the cylinder wall has a chip so whats my best bet.. should i waste 800 on labor too take it out or should i have him put new gasket thats three layers and use indian glue on the chip. would that prevent overheating
da9carl
Mar 13, 2011 04:30 AM
Tad
Jul 5, 2004 04:14 PM
