has anyone used this turbo before?
sc60 turbo?
around how much horsepower can this turbo produce?
I have a B18b1 block with
cp pistons 9.1
eagle rods
ls crank
ACL racing bearings
ARP headstuds
head
skunk 2 valve train
type r cams
STR cam gears
victor x manifold
ericks racing throttle body 68mm (do i need to upgrade?)
golden eagle fuel rail
areomotive fuel pressure regulator
turbo
SC61
peekboost ram horn maniold
tail 38mm wastegate
tail 50mm blov
percision 850hp intercooler
I will be tuning on 100oct
please let me know your opinions about my build what I fix.
will those cams do the trick or should I get skunk 2 pro 1 or are the pro 1 to big or the sc60.
well let me know your opinions
cp pistons 9.1
eagle rods
ls crank
ACL racing bearings
ARP headstuds
head
skunk 2 valve train
type r cams
STR cam gears
victor x manifold
turbo
SC61
tail 38mm wastegate
tail 50mm blov
Sorry man but noone is gonna give you an definetive answer. 400-650??
Depends on tuner, fuel. the way the motor is built, so many thing come into play.
This is far as the thread goes. Sorry bud but you gotta go find out yourself.
Good luck!
Good luck!
keslerbuilt
Jun 21, 2015 07:19 PM
streetracer6rpt
Jun 18, 2007 07:12 PM
jk11blueboi
May 12, 2007 08:28 PM
