How do I clean the car? Sanding between coats
Old May 28, 2010 | 12:52 PM
THEhomelessONE's Avatar
Default How do I clean the car? Sanding between coats
Well I laid down 2 coats of safety red on my e30 and it looks amazingly good for what it is, couldn't be happier. Well I wet sanded the car today with 600 grit and after I was done, it hit me. How do I clean the car after sanding between coats? I masked everything up so I don't want to wash the car like I normally would. Can I just wipe everything down with wet paper towels then dry it after? Do I need to use mineral spirits to clean the car before I lay down another coat of paint? Thanks guys!
This was after one dry coat.
Old May 29, 2010 | 07:51 AM
candyman206's Avatar
Default Re: How do I clean the car? Sanding between coats
you could use a aerosol glass cleaner....but remasking is always best to keep dust off your paint job. the glass cleaner cuts silicone contamination
Old May 30, 2010 | 02:20 PM
h22ej8's Avatar
You should use the same thing you should be using before spraying ANY sort of color.
Grease/wax remover. Spray it on, wipe it off with one towel then go back over it with another (dry) towel to take the residue off.
Old Jun 2, 2010 | 04:40 PM
DieGTi's Avatar
Don't use paper towels as they will leave lint behind. Use old white socks or T-shirts that you have around the house.
Old Jun 6, 2010 | 07:03 PM
FIST321's Avatar
there shouldnt be any lint if u tack it off right or wrong.
Old Jun 7, 2010 | 07:29 PM
Spawne32's Avatar
not sure why nobody has said body shop tack clothes specifically designed for this....and prepsol...
Old Jun 7, 2010 | 10:01 PM
Da-Risin-Smoke's Avatar
I thought you were never supposed to tack the clear coat. Ever.
Someone correct me though.
Old Jun 8, 2010 | 06:48 AM
Spawne32's Avatar
i assumed that as long as it had cured you would be fine
EK9Tune
Nov 9, 2006 08:28 PM
mooseheads36
Honda Civic (2006 - 2015)
14
Aug 7, 2006 07:40 AM
JKS2000
Honda S2000
41
Jul 22, 2004 05:49 AM
Mark
Jun 19, 2003 03:12 PM
