Mugen ECU available ...
Old Sep 12, 2002 | 06:20 PM
ZygSpeed's Avatar
Default Mugen ECU available ...
Asking $850
https://honda-tech.com/zerothread?id=278303
Also the stock ECU from a 97 ITR. Ed
[Modified by Zygspeed, 10:21 PM 9/12/2002]
B2FiNiTY's Avatar
Default Re: Mugen ECU available ... (Zygspeed)
Great midrange with this ECU
Old Sep 12, 2002 | 06:22 PM
TypeR 599's Avatar
Default Re: Mugen ECU available ... (B2FiNiTY)
question-if you get a vafc and tune it, can't you get the same results as just getting an aftermarket ecu?
Old Sep 12, 2002 | 06:23 PM
B2FiNiTY's Avatar
Default Re: Mugen ECU available ... (TypeR 599)
No you cannot. VAFC has it's limits. After all...it's only a piggy back.
Old Sep 12, 2002 | 06:25 PM
ZygSpeed's Avatar
VAFC tuning might actually help in some circumstances, however the Mugen ECU also has it's own mind with respect to ignition timing,
and it doesn't throw codes for a secondary O2 if you don't have or run one (I don't).
[Modified by Zygspeed, 10:26 PM 9/12/2002]
Old Sep 12, 2002 | 06:27 PM
Willard's Avatar
revs =
TypeR 599's Avatar
ohh ok thanks
Old Sep 12, 2002 | 07:09 PM
PYITR821's Avatar
How about a p28 with the mugen program?
Old Sep 12, 2002 | 07:14 PM
ZygSpeed's Avatar
Default Re: Mugen ECU available ... (PYITR821)
I've always wondered what the "Mugen Program" consisted of,
especially since the Mugen ECU is supposeadly different internally with respect to a factory ECU.
I think I've still got that link somewhere on my work computer. Ed
Old Sep 12, 2002 | 07:39 PM
EPGONZALEZ's Avatar
mugen ecu has been so good to me...
some one better nab this before i grab it for my gsr
Old Sep 13, 2002 | 09:54 AM
Euro98ITR's Avatar
Default Re: Mugen ECU available ... (Willard)
How much does the engine rev with the Mugen ECU??
Old Sep 13, 2002 | 09:55 AM
B2FiNiTY's Avatar
Default Re: Mugen ECU available ... (SF-ITR)
I believe 9200 RPM or I could be wrong and it's 9100 RPM.
Old Sep 13, 2002 | 09:58 AM
RC211V's Avatar
will mugen ecu work with obdII? and do the toda b's make power until 9.1k?
Old Sep 13, 2002 | 10:20 AM
ZygSpeed's Avatar
Default Re: Mugen ECU available ... (JDMintegGSR)
The rev limit is @9100.
To use with OBD II it would be ok since it works fine on my 97 ITR, but with the 2000 and '01 cars the ECU plug changed so you'd need a harness adapter.
From what I hear from those with Toda B's, they do make power up to or around 9100 (but some fuel tuning might be needed with a VAFC as well). Ed
[Modified by Zygspeed, 2:21 PM 9/13/2002]
Old Sep 13, 2002 | 12:02 PM
Doctor CorteZ's Avatar
bump fo' Ed
you going to ricer nobles next thursday? I guess I'll go to one of these things sometime
Old Sep 13, 2002 | 12:08 PM
ZygSpeed's Avatar
Default Re: Mugen ECU available ... (Doctor CorteZ)
Nope, car will be undergoing it's transformation shortly and I just did a few of those to see who's in the area and say "hello".
Jamie, how about those 1st gen Prelude Si injectors for the turbo Rex project?
The CCR is beconing.
Old Sep 13, 2002 | 12:11 PM
lemme know when
I still havent had a chance to rebuild Steve's calipers .... soon hopefully though
Old Sep 13, 2002 | 01:15 PM
Smitdog's Avatar
TTT for Ed!!
Old Sep 13, 2002 | 01:38 PM
Smitdog's Avatar
Default Re: Mugen ECU available ... (Smitdog)
U have a IM Ed!
Old Sep 13, 2002 | 04:45 PM
ZygSpeed's Avatar
Thanks Steve, talk to you soon.
Zoom, zooom!
hehe ... Yeah Jamie, Steve mentioned that the other night when I dropped off my coated head for my fresh turbo motor.
[Modified by Zygspeed, 8:47 PM 9/13/2002]
Old Sep 13, 2002 | 04:49 PM
Euro98ITR's Avatar
When doe the VTEC engage ? Is it 4700RPM?
Will it fit a Eurospec ITR ? My ITR has a OBDII style ecu (P73)
Old Sep 13, 2002 | 05:02 PM
ZygSpeed's Avatar
Sandro, yes the VTEC crossover comes in at about 4700, and the redline is in the 9100 range (though things look just a bit off on the stock tach as I'm sure you might know).
It plugs right into my ECU harness on my 97 ITR, and I'm guessing that it will do so as well on your 98.
However, the only trick is that two wires need to be "re-wired/connected" in the wiring harness in order to get the air conditioning to run.
Thanks for the inquiry, Ed
Old Sep 13, 2002 | 05:13 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Or you could buy a P28/Hondata 2/obdii adapter AND dyno time.
Old Sep 13, 2002 | 05:19 PM
SoCal ITR's Avatar
Default Re: Mugen ECU available ... (SkyeC)
If I didn't know your plans, I'd ask if you were tired of using soft-scrub to clean your car...
Bump for Crazy Ed...
Old Sep 13, 2002 | 05:21 PM
ZygSpeed's Avatar
Exactly what I'm getting for my boost fueling solution!
Chris ... there will always be a use for softscrub when I eventually wash my car!
After a conversation with a VA Trooper wherein he asks me if I was one of the F & F, ... D has dubbed me F&F Ed!
And if I may indulge the MODS just a bit longer, I also have my stock 97 ITR ECU ... to go. Ed
[Modified by Zygspeed, 9:26 PM 9/13/2002]
